Old 9th December 2007, 10:34 PM   #1
Default Simple Guitar Distortion Pedal
Hey,
This winter break I'd like to finally site down and make a distortion pedal for my guitar, mainly because I would like one and the knowledge to make them.
So over the past few months I've been looking at using transistors on and off from a number of sources. But none of them have really helped me for some reason.
The idea is to make one similar to the old fuzz-face pedals, but with NPN Silicon transistors (or MOSFETs???).
Attached is a basic schematic that I have drawn up (it's almost identical to the fuzz-face pedals.)
Now what I actually want to know from you guys is:
-How should I go about choosing transistors?
-How do I go about choosing resistor values for the transistors?
-What is the input voltage from a Guitar (I've got Humbuckers so they are pretty high gain). I've heard that 500mV is a reasonable figure to use?
-What kind of gain should I be going for?
-Should I even be biasing the first transistor to get the sound I want? (aka Fuzz-Face)
-Is my coupling capacitor pointing in the right direction?
-Is 100uF a reasonable value for the supply capacitor? If I were to use a battery.
-How do I find out what kind of values I should use for the coupling capacitors? My guess is that I use 1/(2(pi)f) where f is the lowest frequency the guitar could produce. And should they both be the same value?
-Do I need to add any capacitors in parallel around the emitter resistors?
-Do I need a resistor before the first transistor?
-If I were to add a pot along the negative feedback path would kind of value should I go for? Does this control gain?
-Would 50k be a reasonable value for P1?
And please don't just tell me the answer I would really like to know why it is I am doing something so that I can have an understanding of the subject.
Thanks for any help or suggestions in advance,
Trevor
(PS: I'm not doing this for homework I assure you, I'd just like to learn a bit before second year engineering in which I'll actually start this kind of stuff.)
TrevorP is offline
Old 10th December 2007, 05:35 PM   #2
Ok so I'm trying to figure some of this stuff out and am I right in assuming that the total current drawn from the battery will be equal to the sum of the currents going through R1, R3 and R6? NOT C2 because C2 will charge up and only deal with slight oscillations.
TrevorP is offline
Old 10th December 2007, 06:35 PM   #3
As those are the only possible current paths you are correct, the slight leakage of C2 can be ignored.
Nigel Goodwin is online now
Old 10th December 2007, 07:23 PM   #4
Ok that makes sense then.
Ok so would the current through R1 be equal to 9v/(R1 + R2) OR 9v/(R1 + (R2+R4)/(R2*R4)).
I'm basically asking if I consider R4 to be in parallel with R2.
TrevorP is offline
Old 10th December 2007, 11:23 PM   #5
No, R4 isn't in parallel with R2.
Old 11th December 2007, 02:05 AM   #6
So base current would be (9v/(R1 + R2)) then?
TrevorP is offline
Old 11th December 2007, 02:07 AM   #7
Your circuit doesn't have any solder-joint "dots" so it is difficult to see if lines cross or connect.
Look in Google at Fuzz Face Circuits to see many.
The best link in Google is this one: http://www.geofex.com/Article_Folder...ace/fftech.htm
Here is a modern version that uses silicon transistors:
audioguru is online now
Old 11th December 2007, 02:09 AM   #8
Yeah sorry about that the program I am using has hard to see dots...for my diagram the only thing that is crossing and not connected is the R3 wire and the negative feedback wire.
TrevorP is offline
Old 11th December 2007, 02:37 AM   #9
Your circuit doesn't work.
I added some solder joint dots and it is clear that it has positive feedback instead of negative feedback.
Look again at the circuit I posted before.
Old 11th December 2007, 02:45 AM   #10
Ohh shit your right... that should be going from the emitter of the second transistor to the base of the first...not collector to emitter.
TrevorP is offline
Old 11th December 2007, 02:51 AM   #11
The negative feedback is supposed to be through a resistor so the transistors are not shorted together.
Old 11th December 2007, 02:55 AM   #12
Hey ok so I made some changes to it and here is what I have now.
I decided to go with a 100uF supply bypass capacitor it was recommended for the same purpose before.
TrevorP is offline
Old 11th December 2007, 03:03 AM   #13
My Fuzz face circuit doesn't have your R1, R2 and R4. Its negative feedback adjusts the AC, not the DC like yours does.
Old 11th December 2007, 03:06 AM   #14
Wait can you possibly explain that to me? How does my negative feedback adjust the DC? and what is the difference?
I understand that mine has initial DC biasing...is it because mine has no capacitors going to ground from the negative feedback loop?
TrevorP is offline
Old 11th December 2007, 04:41 AM   #15
The DC of your circuit changes when the gain control is changed. Mine doesn't.
Your circuit is not a fuzz-Face. It is different.
distortion, guitar, pedal, simple
Simple Robot From Scratch Parts? GreenAce92 Robotics Chat 7 28th October 2007 12:42 AM
making a simple bass Guitar Amp. FranklinR Electronic Projects Design/Ideas/Reviews 10 19th October 2006 02:52 PM
Keyboard sustain pedal Dan East General Electronics Chat 8 17th July 2006 07:38 PM
Acoustic guitar amp VS Guitar amp Johnson777717 Electronic Projects Design/Ideas/Reviews 2 3rd February 2004 03:16 AM
simple help.. Making a simple amplifier. pls help urgent. paulbostaph General Electronics Chat 19 20th May 2003 05:32 PM
