Old 8th December 2007, 06:47 AM   #1
Default 1 to 200 Hz signal generator
I need to make up an adjustable 1 to 200 Hz square wave signal generator, current sink output, to test a PLC I'm having some issues with. The system is 24 volt DC. Any ideas where to look for a circuit would be much appreciated.
Thanks for your time
phyxit is offline
Old 8th December 2007, 09:06 AM   #2
There are many ways to go here.
Grep for XR-2206 circuits on the web. You need 3 decades to cover from 1 to 200Hz, and this chip will do five. It needs several hand-fulls of resistors and capacitors for full functionality, but you may not need it all. Jameco Electronics sells just the chip for $3.59 and also a basic function generator in kit form for $25:
http://www.jameco.com/webapp/wcs/sto...roductId=34972
http://www.jameco.com/webapp/wcs/sto...roductId=20685
You specified the system voltage but not what your square wave output amplitude must be. You'd also have to elaborate about your current sink requirement.
And finally, you'll need to drop the 24V to 12V if you build the kit, which is easy to do with an LM78L12 voltage regulator and a couple of caps. The above circuit draws only 15mA. The chip, however, can tolerate a 26V supply.
This may get you started. Good luck,
Corey
saturn1bguy is offline
Old 8th December 2007, 09:47 AM   #3
Thanks for the help Corey, PLC i/p held at 24v by 10k resistor so this should work fine
phyxit is offline
Old 8th December 2007, 10:04 PM   #4
Hi Phyxit,
Here's another one for you, not as fancy as the Jameco
thing but it should work equally well. If the logical zero isn't
low enough you can always add a transistor or a fet to
drive the plc.
on1aag.
on1aag is offline
200, generator, signal
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 02:45 PM
2400MHz signal generator sums Electronic Projects Design/Ideas/Reviews 0 30th January 2004 09:38 AM
Wide Band Signal Generator CParsec General Electronics Chat 1 27th September 2003 03:48 AM
Single PIC16F84 audio signal generator Free Flyer Micro Controllers 1 23rd February 2003 07:10 AM
