| I have a switch mode power supply that has two 250V 220uf caps. I am unable to obtain the filter Caps in the dia and length that I require (23mm Dia x 30mm length) Board mount. Can I replace the caps with 250V 330uf caps that I can obtain in the correct dimensions. By using this 330uf cap's would this give a more smoother DC wave sign. Is this the only thing that will change, or is there other effects on the circuit. | |
| Should be fine, bear in mind the wide tolerance of electrolytics anyway!. | |
| Thank you for your help.and advice. Greg Have a Merry Christmas | |
| Just make sure the caps are designed for switch mode supplies. ie: designed with low ESR and high frequency/current ripple in mind.
__________________ --- The days of the digital watch are numbered. --- | |
Ofcourse, I understand the need for return path of the switched energy on the inputside. while generally Low ESR caps are prescribed on the output side. That is what made me to request for clarity.
| Using Caps on a 3 phase genny | bryan1 | General Electronics Chat | 6 | 9th October 2007 08:20 PM |
| Power Filter Caps, how do you know how big they should be? | joecool85 | General Electronics Chat | 6 | 10th April 2006 03:23 AM |
| Peculiar filter bandpass filter requirements | Fish | Electronic Projects Design/Ideas/Reviews | 6 | 12th March 2005 04:36 PM |
| Filter problem... Very urgent pls.. | kingkong83 | Electronic Projects Design/Ideas/Reviews | 23 | 19th October 2004 02:40 AM |
| Power Supply Filter Caps | Eclipsed | General Electronics Chat | 6 | 24th October 2003 05:16 PM |
