+ Reply to Thread
Page 3 of 6
First 1 2 3 4 5 6 Last
Results 31 to 45 of 90
Thread: HELP me build a gas gauge????
  1. #31
    browningbuck Bad browningbuck Bad
    Join Date
    Aug 2007
    Location
    Utah west jordan
    Posts
    121
    okay the direction on the LEDs are correct...they light up how htey should
    if i where to put this together would this work...please look at the alt to the fuel gauge part
  2. #32
    Darth Bagel Newbie
    Join Date
    Oct 2007
    Posts
    44
    I was referring to this schematic. My apologies if that wasn't the one being referenced.
  3. #33
    chemelec Good chemelec Good chemelec Good chemelec Good
    Join Date
    Apr 2004
    Location
    B.C. Canada
    Posts
    1,078
    Quote Originally Posted by browningbuck
    oh you totally screwedm me up now... so would this still need that amp circuit that SPDCHK had designed....i will have to give this a try tonight
    i have a 1.2K and a 3.8K resistor will that be okay?? i dont want to run to the store today but i might have to
    Yes, 3.8K is OK.
    No you Don't need that Op-Amp.
    I never Built this to test it, But it should work.
    Give it a try.
    Gary
    I No Longer accept Private Messages on here.
    All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
    or they go Directly to my Junk Mail Folder.
    Email me at: chemelec@hotmail.com
    Website: http://www3.telus.net/chemelec
  4. #34
    Join Date
    Aug 2007
    Location
    Utah west jordan
    Posts
    121
    Okay Chemelec i LOVE it now that ive looked at it, just one question. is it okay to shoot that 12V down to the potentiometer that is surrounded by GAS?????
  5. #35
    Join Date
    Apr 2004
    Location
    B.C. Canada
    Posts
    1,078
    If it is a PROPER SENDER potentiometer, made to be in the gasoline, it should be OK.
    But other than that, I can't say without knowing the real quality of that part.
  6. #36
    Join Date
    Aug 2007
    Location
    Utah west jordan
    Posts
    121
    okay sweet , yeah it comes straight from Honda and is made for it to be in gas (just didnt know if orginally a lower voltage was sent to it)
    tomorrow morning i will have results!!!!!!!
  7. #37
    Join Date
    Aug 2007
    Location
    Utah west jordan
    Posts
    121
    DYUMN chemelec it worked...it has some small bugs to work out (like once i hit the very to of full it doesnt show a light..but just a slight bit off full it comes on) then i need to get some diodes in there so it acts like a fuel gauge(only one light is on at any give point) then the final thing i need to work out(inbetween positions from one light to the next there may be no light showing at all until i get to the next one(i think the diodes will fix that))
  8. #38
    superbrew Okay
    Join Date
    Oct 2007
    Location
    Nashua, NH
    Posts
    101
    How do you have pin 9 connected? If you want "dot" mode then leave it open, otherwise connect it to pin 3 and it will be in "bar" mode.
  9. #39
    Join Date
    Aug 2007
    Location
    Utah west jordan
    Posts
    121
    AHHHHHHH sweet that will solve that proble and i wont have to use diodes
    that make me REAL happy
    hey how do i open up the range a little (so that it would range from 11 ohms to 132ohms???) would that be off the 150ohm resistor that i would make bigger????
  10. #40
    Join Date
    Apr 2004
    Location
    B.C. Canada
    Posts
    1,078
    Instead of only using the 5 LED's as you mentioned, Why not use ALL 10 LED's?
    It will Work Better and definately show Full.
    Edit: And As I said previously:
    That 150 Ohm resistor was Only an Aproximate Value. It may need to be slightly Lower or Higher to get an Exact range for what you want.
    (I only used the 150 Ohms, as it is a Standard, off the shelf value.)
    Gary
  11. #41
    Join Date
    Aug 2007
    Location
    Utah west jordan
    Posts
    121
    here is why i cant use 10...i could use sx like i said earlier..not enough room
    this is a small little buisness i have putting intergrated gear indicators on bikes (the 7 seg. display in the middle) then bunches of people wanted me to design a fuel gauges and thats where i am at (the fuel leds are just photoshoped as you can tell ) BOY I LOVE LEDs
  12. #42
    Join Date
    Apr 2004
    Location
    B.C. Canada
    Posts
    1,078
    Well there are Small LED's and there are SMALLER LED's.
    I have some here that are only 1/16 Inch Square.
    Side by Side, 10 would be 5/8 Inch Long.
    But Anyway, Have FUN.
    GARY
  13. #43
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    Very cool looking design.
    As said already there are a zillion different LED designs. You might want to consider looking around before freezing your project.
    Here are just a few ideas:
    http://cgi.ebay.com/HDSP-4830-LED-BA...QQcmdZViewItem
    http://cgi.ebay.com/Submini-RED-LED-...QQcmdZViewItem
    http://cgi.ebay.com/Red-Symbol-LED-5...QQcmdZViewItem
    Lefty
    Measurement changes behavior
  14. #44
    Join Date
    Aug 2007
    Location
    Utah west jordan
    Posts
    121
    only reason i can down grade in size is due to mcd they will in the end have a photo resistor, and have to be bright enough in the day to be clairly visable, on a motorcycle, and plus 5 is cheaper and more simple for me to sell (less holes i have to drill in an $80 face plate)
    i still have a prob with getting this in bar mode instead of dot i have tried as said before connecting pin 3 and 9 (no luck) any sugestions????? and the project has not been put on pause it was just the weekend i had to work on 3 sets of gauges
    i kinda liked this one a little
  15. #45
    TrevorP Newbie
    Join Date
    Dec 2006
    Posts
    198
    To get it in bar mode simply provide power to the Mode Node...if that doesn't work then something is messed and you should try another chip of the same type.
+ Reply to Thread
Page 3 of 6
  1. Pickit 2 - Build or Not 2 Build
    By art-666 in forum Micro Controllers
    Latest: 5th February 2007, 11:40 PM
  2. FET & Fuel Gauge - perplexed!
    By rackley in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd December 2006, 06:25 PM
  3. automotive fuel sender unit / fuel gauge
    By drage in forum General Electronics Chat
    Latest: 20th October 2006, 06:37 PM
  4. AFR (Air/fuel ratio) gauge
    By Blueteeth in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd October 2006, 05:47 PM
  5. SMPS power suply modify or build plss
    By Raducu in forum General Electronics Chat
    Latest: 9th February 2006, 12:53 AM
Tags for this Thread
