Old 4th December 2007, 07:55 AM   (permalink)
Experienced Member
Dawny is on a distinguished road
Default Substituting a 16x2 LCD display for 16x1 LCD display?
Hello again.
Sorry to bug you all again so soon but, does anyone know if I can substitute a 16x2 LCD display when a PIC circuit calls for a 16x1 LCD display?
Thanks in advance.
Dawn
Dawny is offline   Reply With Quote
Old 4th December 2007, 09:00 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Yes you can and it will just use the top line unless you modify the code. Do you have access to the source code?
Pommie is offline   Reply With Quote
Old 4th December 2007, 11:54 AM   (permalink)
Experienced Member
Yea most likely I do have access to the source code but at the moment editing would be far beyond what I can do...
Dawn
Old 4th December 2007, 01:32 PM   (permalink)
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
Dawn
If you need a little help, post your existing code, together with a note covering the small changes you would to make to it.
Eric
"Good enough is Perfect"
PIC tutorials:
Nigel's: www.winpicprog.co.uk/
Gramo's: www.digital-diy.net/
Old 6th December 2007, 05:17 AM   (permalink)
Experienced Member
To be honest I'm not sure who wrote this code but the code I'm using is as follows...
; PFC-50 POCKET FREQUENCY COUNTER
;WATCHDOG DISABLED
LIST P=16F84A
#include <p16F84A.inc>
__CONFIG _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_ALL
RS EQU 2H
RW EQU 1H
E EQU 0H
O EQU 7H
COUNT1 EQU 2CH
COUNT2 EQU 2DH
IN_REG EQU 2EH
ADDCNT EQU 2FH
GATE EQU 0CH
CNT1 EQU 0DH
CNT2 EQU 0EH
CNT3 EQU 0FH
CALC1 EQU 10H
CALC2 EQU 11H
CALC3 EQU 12H
SUM1 EQU 13H
SUM2 EQU 14H
SUM3 EQU 15H
RTCC2 EQU 16H
TEMP1 EQU 17H
TEMP2 EQU 18H
COUNT3 EQU 19H
COUNT4 EQU 1AH
ORG 0
GOTO START
INT_DEL:
MOVLW 0X05 ;DELAY 5.000 MS (4 MHZ CLOCK)
MOVWF COUNT1
D1 MOVLW 0XA5
MOVWF COUNT2
D2 DECFSZ COUNT2,F
GOTO D2
DECFSZ COUNT1,F
GOTO D1
RETLW 0X00
MIRROR:
CLRF TEMP2
MOVWF TEMP1
BTFSC TEMP1,0
BSF TEMP2,7
BTFSC TEMP1,1
BSF TEMP2,6
BTFSC TEMP1,2
BSF TEMP2,5
BTFSC TEMP1,3
BSF TEMP2,4
BTFSC TEMP1,4
BSF TEMP2,3
BTFSC TEMP1,5
BSF TEMP2,2
BTFSC TEMP1,6
BSF TEMP2,1
BTFSC TEMP1,7
BSF TEMP2,0
MOVF TEMP2,W
RETURN
LCD_OUT:
CALL MIRROR
MOVWF PORTB ;LOAD DATA INTO PORTB
BSF STATUS,RP0
MOVLW B'00000000' ;DEFINE PORTB AS OUTPUT
MOVWF TRISB
BCF STATUS,RP0
BSF PORTA,RS ;RS = DATA
BCF PORTA,RW ;R/W = WRITE
BSF PORTA,E ;TOGGLE ENABLE
BCF PORTA,E
BSF STATUS,RP0
MOVLW B'11111111' ;DEFINE PORTB AS INPUT
MOVWF TRISB
BCF STATUS,RP0
BCF PORTA,RS ;RS = INSTRUCTION
BSF PORTA,RW ;R/W = READ
BSF PORTA,E ;ENABLE HIGH
MOVF PORTB,W ;GET ADDRESS COUNTER
CALL MIRROR
MOVWF ADDCNT
BSF ADDCNT,7
BCF PORTA,E ;ENABLE LOW
OUT1 BSF PORTA,E ;ENABLE HIGH
BTFSS PORTB,0 ;TEST BUSY FLAG
GOTO OUT2
GOTO OUT1
OUT2 BCF PORTA,E ;ENABLE LOW
GOTO SHIFT
INST:
CALL MIRROR
MOVWF PORTB ;LOAD INSTRUCTION INTO PORTB
BSF STATUS,RP0
MOVWF TRISB
BCF STATUS,RP0
BCF PORTA,E
BSF STATUS,RP0
MOVWF TRISB
BCF STATUS,RP0
INST1:
GOTO INST2
GOTO INST1
INST2:
RETLW 0X00
; LCD 16X1
SHIFT:
BTFSS ADDCNT,0 ;SHIFT TO OPPOSITE SIDE OF DISPLAY?
RETLW 0X00
BTFSS ADDCNT,1
RETLW 0X00
BTFSS ADDCNT,2
RETLW 0X00
MOVLW 0XC0
MOVF ADDCNT,W
MOVLW 0XC0
GOTO INST
SUB BCF STATUS,O ;CLEAR OVERFLOW BIT
MOVF CALC1,W ;SUBTRACT CALC1 FROM CNT1
SUBWF CNT1 ,F
BTFSC STATUS,C
GOTO SB1
MOVLW 0X01 ;BORROW FROM CNT2 IF OVERFLOW
SUBWF CNT2 ,F
BTFSC STATUS,C
GOTO SB1
SUBWF CNT3 ,F ;BORROW FROM CNT3 IF CNT2 OVERFLOW
BTFSS STATUS,C
BSF STATUS,O ;SET OVERFLOW BIT IF RESULT IS NEGATIVE
SB1 MOVF CALC2,W ;SUBTRACT CALC2 FROM CNT2
SUBWF CNT2 ,F
BTFSC STATUS,C
GOTO SB2
MOVLW 0X01 ;BORROW FROM CNT3 IF CNT2 OVERFLOW
SUBWF CNT3 ,F
BTFSS STATUS,C
SB2 MOVF CALC3,W ;SUBTRACT CALC3 FROM CNT3
SUBWF CNT3 ,F
BTFSS STATUS,C
RETLW 0X00
ADD MOVF CALC1,W ;ADD CALC1 TO CNT1
ADDWF CNT1 ,F
BTFSS STATUS,C
GOTO AD1
INCFSZ CNT2 ,F ;ADD TO CNT2 IF CNT1 OVERFLOW
GOTO AD1
INCF CNT3 ,F ;ADD TO CNT3 IF CNT2 OVERFLOW
AD1 MOVF CALC2,W ;ADD CALC2 TO CNT2
ADDWF CNT2 ,F
BTFSC STATUS,C
MOVF CALC3,W ;ADD CALC3 TO CNT3
ADDWF CNT3 ,F
RETLW 0X00
CNVT MOVLW 0X07 ;7 DIGITS IN DISPLAY
MOVWF COUNT1
MOVLW 0X19 ;SET FSR FOR MSB IN DISPLAY
MOVWF FSR
MOVLW 0X2F ;ONE LESS THAT ASCII "0"
CNVT0:
MOVWF INDF
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO CNVT0
MOVLW 0X0F ;LOAD "1,000,000" IN CALC1-3
MOVWF CALC3
MOVLW 0X42
MOVWF CALC2
MOVLW 0X40
MOVWF CALC1
CNVT1:
CALL SUB ;SUBTRACT NUMBER FROM COUNT
INCF 19 ,F ;INCREMENT 1,000,000'S REGISTER
MOVLW 0X3A
XORWF 19,W
BTFSC STATUS,Z
GOTO OVERFLOW
BTFSS STATUS,O ;CHECK IF OVERFLOW
GOTO CNVT1
CALL ADD ;ADD BACK LAST NUMBER
MOVLW 0X01 ;LOAD "100,000" IN CALC1-3
MOVWF CALC3
MOVLW 0X86
MOVWF CALC2
MOVLW 0XA0
MOVWF CALC1
CNVT2:
INCF 1A ,F ;INCREMENT 100,000'S REGISTER
GOTO CNVT2
CLRF CALC3 ;LOAD "10,000" IN CALC1-3
MOVLW 0X27
MOVWF CALC2
MOVLW 0X10
MOVWF CALC1
CNVT3:
INCF 1B ,F ;INCREMENT 10,000'S REGISTER
GOTO CNVT3
MOVLW 0X03 ;LOAD "1,000" IN CALC1-3
MOVWF CALC2
MOVLW 0XE8
MOVWF CALC1
CNVT4:
INCF 1C ,F ;INCREMENT 1,000'S REGISTER
GOTO CNVT4
CLRF CALC2 ;LOAD "100" IN CALC1-3
MOVLW 0X64
MOVWF CALC1
CNVT5:
INCF 1D ,F ;INCREMENT 100'S REGISTER
GOTO CNVT5
CALL ADD ;ADD BACK NUMBER
MOVLW 0X0A ;LOAD "10" IN CALC1-3
MOVWF CALC1
CNVT6:
INCF 1E ,F ;INCREMENT 10'S REGISTER
GOTO CNVT6
MOVF CNT1,W ;PUT REMAINDFER IN 1'S REGISTER
ADDWF 1F ,F
INCF 1F ,F
RETLW 0X00
COUNT:
BSF STATUS,RP0
MOVLW B'00110111' ;TMR0 = EXT, 1/256
MOVWF OPTION_REG
MOVLW B'00010000' ;DEFINE PORTA AS OUTPUT
MOVWF TRISA
BCF STATUS,RP0
BCF PORTA,3
BCF PORTA,2
CLRF CNT3
CLRF TMR0
CLRF RTCC2
BSF PORTA,2 ;TOGGLE TMR0 PIN
BCF PORTA,2
MOVF GATE,W ;GET GATE TIME
MOVWF COUNT1
BSF PORTA,3 ;START COUNT
FR4 MOVLW 0XFA
MOVWF COUNT2
GOTO FR6
FR5 NOP
NOP
NOP
NOP
NOP
NOP
FR6 MOVF TMR0,W ;TEST FOR TMR0 ROLLOVER (12)
SUBWF RTCC2 ,F
BTFSS STATUS,Z
GOTO FR7
NOP
GOTO FR8
FR7 BTFSC STATUS,C
INCF CNT3 ,F
FR8 MOVWF RTCC2
NOP
NOP
NOP
DECFSZ COUNT2 ,F
GOTO FR5
DECFSZ COUNT1 ,F
GOTO FR4
BCF PORTA,3 ;STOP COUNT
MOVF TMR0,W ;GET TMR0 COUNT
MOVWF CNT2
SUBWF RTCC2 ,F ;TEST FOR TMR0 ROLLOVER
BTFSS STATUS,C
GOTO FR9
BTFSS STATUS,Z
INCF CNT3 ,F
FR9 CLRF CNT1 ;SET TO GET PRESCALER COUNT
FR10 DECF CNT1 ,F
BCF PORTA,2
MOVF TMR0,W ;TEST IF TMR0 HAS CHANGED
XORWF CNT2,W
BTFSC STATUS,Z
GOTO FR10
RETLW 0X00
; START MAIN PROGRAM
START:
CLRF PORTA ;INSTRUCTION, WRITE, ENABLE LOW
CLRF PORTB
BSF STATUS,RP0
MOVLW B'00010000'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISB
BCF STATUS,RP0
CALL INT_DEL
CALL INT_DEL
CALL INT_DEL
MOVLW 0X38 ;INITIALIZE DISPLAY
CALL MIRROR
MOVWF PORTB
CALL INT_DEL
BCF PORTA,E
CALL INT_DEL
BCF PORTA,E
CALL INT_DEL
BCF PORTA,E
MOVLW 0X38 ;FUNCTION
CALL INST
MOVLW B'00001100' ;DISPLAY ON, CURSOR OFF
CALL INST
MOVLW B'00000001' ;CLEAR DISPLAY
CALL INST
MOVLW B'00000110' ;ENTRY MODE
CALL INST
; NEW LINES HERE FOR INTRO
MOVLW 0X50 ;P
CALL LCD_OUT
MOVLW 0X46 ;F
CALL LCD_OUT
MOVLW 0X43 ;C
CALL LCD_OUT
MOVLW 0X2D ;-
CALL LCD_OUT
MOVLW 0X35 ;5
CALL LCD_OUT
MOVLW 0X30 ;0
CALL LCD_OUT
MOVLW 0X06 ;CHANGE THE 6 TO A SMALLER NO. TO SPEED UP THE INTRO
MOVWF COUNT3
WAIT1:
MOVLW 0XC8
MOVWF COUNT4
WAIT2:
CALL INT_DEL
DECFSZ COUNT4 ,F
GOTO WAIT2
DECFSZ COUNT3 ,F
GOTO WAIT1
CALL INST
MHZ MOVLW 0X14 ;0.1 SEC GATE
MOVWF GATE
CALL COUNT
CALL CNVT ;CONVERT BINARY TO BCD
MOVLW 0X30 ;TEST IF "0"
XORWF 19,W
BTFSS STATUS,Z
GOTO MHZ1
XORWF 1A,W
BTFSC STATUS,Z
GOTO KHZ1
MHZ1 MOVLW 0X82 ;SET DISPLAY ADDRESS
CALL INST
MOVLW 0X02 ;OUTPUT FIRST 2 CHARACTERS
MOVWF COUNT1
MOVLW 0X19 ;MSD OF FREQ
MOVWF FSR
MHZ2 MOVLW 0X30 ;TEST IF "0"
XORWF INDF,W
BTFSS STATUS,Z
GOTO MHZ3
MOVLW 0X20 ;CHANGE PRECEEDING "0'S" TO "SPACE"
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO MHZ2
GOTO MHZ4
MHZ3 MOVF INDF,W
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO MHZ3
MHZ4 MOVLW 0X2E ;"."
CALL LCD_OUT
MOVLW 0X05 ;OUTPUT LAST 5 CHARACTERS
MOVWF COUNT1
MHZ5 MOVF INDF,W
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO MHZ5
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X4D ;"M"
CALL LCD_OUT
MOVLW 0X48 ;"H"
CALL LCD_OUT
MOVLW 0X7A ;"Z"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
GOTO MHZ
KHZ MOVLW 0X14 ;0.1 SEC GATE
MOVWF GATE
CALL COUNT
MOVLW 0X30 ;TEST IF 0
XORWF 19,W
BTFSS STATUS,Z
GOTO MHZ1
MOVLW 0X32 ;TEST IF < 2
SUBWF 1A,W
BTFSC STATUS,C
GOTO MHZ1
XORWF 1A,W
BTFSS STATUS,Z
GOTO KHZ1
XORWF 1B,W
BTFSC STATUS,Z
GOTO XKHZ
KHZ1 MOVLW 0X82 ;SET DISPLAY ADDRESS
CALL INST
MOVLW 0X05 ;OUTPUT FIRST 5 CHARACTERS
MOVWF COUNT1
MOVWF FSR
KHZ2 MOVLW 0X30 ;TEST IF "0"
XORWF INDF,W
BTFSS STATUS,Z
GOTO KHZ3
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO KHZ2
GOTO KHZ4
KHZ3 MOVF INDF,W
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO KHZ3
KHZ4 MOVLW 0X2E ;"."
CALL LCD_OUT
MOVF INDF,W ;OUTPUT LAST 2 CHARACTERS
CALL LCD_OUT
INCF FSR ,F
MOVF INDF,W
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X4B ;"K"
CALL LCD_OUT
MOVLW 0X48 ;"H"
CALL LCD_OUT
MOVLW 0X7A ;"Z"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
GOTO KHZ
XKHZ MOVLW 0XC8 ;1 SEC GATE
MOVWF GATE
CALL COUNT
XORWF 19,W
BTFSS STATUS,Z
GOTO KHZ
SUBWF 1A,W
BTFSC STATUS,C
GOTO KHZ
XORWF 1A,W
BTFSS STATUS,Z
GOTO XKHZ1
XORWF 1B,W
BTFSC STATUS,Z
GOTO HZ0
XKHZ1:
CALL INST
MOVLW 0X04 ;OUTPUT FIRST 4 CHARACTERS
MOVWF COUNT1
MOVWF FSR
XKHZ2:
XORWF INDF,W
BTFSS STATUS,Z
GOTO XKHZ3
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO XKHZ2
GOTO XKHZ4
XKHZ3:
MOVF INDF,W
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO XKHZ3
XKHZ4:
MOVLW 0X2E ;"."
CALL LCD_OUT
MOVF INDF,W ;OUTPUT LAST 3 CHARACTERS
CALL LCD_OUT
INCF FSR ,F
MOVF INDF,W
CALL LCD_OUT
INCF FSR ,F
MOVF INDF,W
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X4B ;"K"
CALL LCD_OUT
MOVLW 0X48 ;"H"
CALL LCD_OUT
MOVLW 0X7A ;"Z"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
GOTO XKHZ
MOVWF GATE
CALL COUNT
XORWF 19,W
BTFSS STATUS,Z
GOTO XKHZ1
XORWF 1A,W
BTFSS STATUS,Z
GOTO XKHZ1
SUBWF 1B,W
BTFSC STATUS,C
GOTO XKHZ1
HZ0 MOVLW 0X82 ;SET DISPLAY ADDRESS
CALL INST
MOVLW 0X07 ;OUTPUT FIRST 7 CHARACTERS
MOVWF COUNT1
MOVWF FSR
HZ1 MOVLW 0X30 ;TEST IF "0"
XORWF INDF,W
BTFSS STATUS,Z
GOTO HZ2
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO HZ1
GOTO HZ3
HZ2 MOVF INDF,W
CALL LCD_OUT
INCF FSR ,F
DECFSZ COUNT1 ,F
GOTO HZ2
HZ3 MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X48 ;"H"
CALL LCD_OUT
MOVLW 0X7A ;"Z"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
MOVLW 0X20 ;"SPACE"
CALL LCD_OUT
GOTO HZ
OVERFLOW:
MOVLW 0X01 ;CLEAR DISPLAY
CALL INST
MOVLW 0X84 ;DISPLAY ADDRESS
CALL INST
MOVLW 0X4F ;"O"
CALL LCD_OUT
MOVLW 0X76 ;"V"
CALL LCD_OUT
MOVLW 0X65 ;"E"
CALL LCD_OUT
MOVLW 0X72 ;"R"
CALL LCD_OUT
MOVLW 0X66 ;"F"
CALL LCD_OUT
MOVLW 0X6C ;"L"
CALL LCD_OUT
MOVLW 0X6F ;"O"
CALL LCD_OUT
MOVLW 0X77 ;"W"
CALL LCD_OUT
MOVLW 0X02 ;CURSOR AT HOME
CALL INST
GOTO MHZ
END
The code is designed for a 16x1 display but all I have on hand is a 16x2 display I don't mind using the display with a blank line but at the moment the code displays half the output on one line and half on the other so lets say you are mesuring a frequance of 3002 Hz it will display it as something like:
Freq: 3
002 Hz
I'm looking for a way to make the code display everything on one line but don't know enough yet to re-write the code to do so...
Dawn.
P.S. Thanks in advance.
Old 6th December 2007, 07:19 AM   (permalink)
Experienced Member
Hi Dawn,
It looks like the code was intended to be used with a display that is arranged as a 2*8 but with one line following the other.
The way to fix it is to put a return instruction on the line with the label SHIFT:
I.E.
SHIFT:    return
I can probably work out how to make it display
PFC-50
Freq: 3002 Hz
If you think it would be worth it.
Old 6th December 2007, 08:05 AM   (permalink)
Experienced Member
hi Dawn,
Mike has already answered your query, so I will not add my four penny worth.
Looks an interesting bit of code, you must let us know how the program changes go.
A suggestion would be, when you post program code after you have placed it in the text window, SELECT the code, then use the menu at the top of the window, click the # symbol [wrap code tags].
This will display all your code including the formatting.
Anyone wishing to run your program, just has to copy and paste, OK.
Hope that makes sense.
Eric
PIC tutorials:
Old 6th December 2007, 10:09 AM   (permalink)
Experienced Member
mvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to all
Send a message via MSN to mvs sarma Send a message via Yahoo to mvs sarma
Originally Posted by ericgibbs
hi Dawn,
To be of help to others, here is the code
;WATCHDOG DISABLED
	LIST P=16F84A
	__CONFIG _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF
	errorlevel -302
RS EQU 2H
RW EQU 1H
E EQU 0H
O EQU 7H
COUNT1 EQU 2CH
COUNT2 EQU 2DH
IN_REG EQU 2EH
ADDCNT EQU 2FH
GATE EQU 0CH
CNT1 EQU 0DH
CNT2 EQU 0EH
CNT3 EQU 0FH
CALC1 EQU 10H
CALC2 EQU 11H
CALC3 EQU 12H
SUM1 EQU 13H
SUM2 EQU 14H
SUM3 EQU 15H
RTCC2 EQU 16H
TEMP1 EQU 17H
TEMP2 EQU 18H
COUNT3 EQU 19H
COUNT4 EQU 1AH
	ORG 0
	GOTO START
INT_DEL:
	MOVWF 	COUNT1
D1 	MOVLW 	0XA5
	MOVWF 	COUNT2
D2 DECFSZ 	COUNT2,F
	GOTO 	D2
	DECFSZ 	COUNT1,F
	GOTO 	D1
	RETLW 	0X00
MIRROR:
	CLRF 	TEMP2
	MOVWF 	TEMP1
	BTFSC 	TEMP1,0
	BSF 	TEMP2,7
	BTFSC 	TEMP1,1
	BSF 	TEMP2,6
	BTFSC 	TEMP1,2
	BSF 	TEMP2,5
	BTFSC 	TEMP1,3
	BSF 	TEMP2,4
	BTFSC 	TEMP1,4
	BSF 	TEMP2,3
	BTFSC 	TEMP1,5
	BSF 	TEMP2,2
	BTFSC 	TEMP1,6
	BSF 	TEMP2,1
	BTFSC 	TEMP1,7
	BSF 	TEMP2,0
	MOVF 	TEMP2,W
	RETURN
LCD_OUT:
	CALL 	MIRROR
	BSF 	STATUS,RP0
	MOVWF 	TRISB
	BCF 	STATUS,RP0
	BCF 	PORTA,E
	BSF 	STATUS,RP0
	MOVWF 	TRISB
	BCF 	STATUS,RP0
	CALL 	MIRROR
	MOVWF 	ADDCNT
	BSF 	ADDCNT,7
	GOTO 	OUT2
	GOTO 	OUT1
	GOTO 	SHIFT
INST:
	CALL 	MIRROR
	BSF 	STATUS,RP0
	MOVWF 	TRISB
	BCF 	STATUS,RP0
	BCF 	PORTA,E
	BSF 	STATUS,RP0
	MOVWF 	TRISB
	BCF 	STATUS,RP0
INST1:
	GOTO 	INST2
	GOTO 	INST1
INST2:
	RETLW 	0X00
; LCD 16X1
SHIFT:
	RETLW 	0X00
	BTFSS 	ADDCNT,1
	RETLW 	0X00
	BTFSS 	ADDCNT,2
	RETLW 	0X00
	MOVLW 	0XC0
	MOVF 	ADDCNT,W
	MOVLW 	0XC0
	GOTO 	INST
	SUBWF 	CNT1 ,F
	BTFSC 	STATUS,C
	GOTO 	SB1
	SUBWF 	CNT2 ,F
	BTFSC 	STATUS,C
	GOTO 	SB1
	BTFSS 	STATUS,C
	SUBWF 	CNT2 ,F
	BTFSC 	STATUS,C
	GOTO 	SB2
	SUBWF 	CNT3 ,F
	BTFSS 	STATUS,C
	SUBWF 	CNT3 ,F
	BTFSS 	STATUS,C
	RETLW 	0X00
	ADDWF 	CNT1 ,F
	BTFSS 	STATUS,C
	GOTO 	AD1
	GOTO 	AD1
	ADDWF 	CNT2 ,F
	BTFSC 	STATUS,C
	ADDWF 	CNT3 ,F
	RETLW 	0X00
	MOVWF 	COUNT1
	MOVWF 	FSR
CNVT0:
	MOVWF 	INDF
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	CNVT0
	MOVWF 	CALC3
	MOVLW 	0X42
	MOVWF 	CALC2
	MOVLW 	0X40
	MOVWF 	CALC1
CNVT1:
	MOVLW 	0X3A
	XORWF 	19,W
	BTFSC 	STATUS,Z
	GOTO 	OVERFLOW
	GOTO 	CNVT1
	MOVWF 	CALC3
	MOVLW 	0X86
	MOVWF 	CALC2
	MOVLW 	0XA0
	MOVWF 	CALC1
CNVT2:
	GOTO 	CNVT2
	MOVLW 	0X27
	MOVWF 	CALC2
	MOVLW 	0X10
	MOVWF 	CALC1
CNVT3:
	GOTO 	CNVT3
	MOVWF 	CALC2
	MOVLW 	0XE8
	MOVWF 	CALC1
CNVT4:
	GOTO 	CNVT4
	MOVLW 	0X64
	MOVWF 	CALC1
CNVT5:
	GOTO 	CNVT5
	MOVWF 	CALC1
CNVT6:
	GOTO 	CNVT6
	ADDWF 	1F ,F
	INCF 	1F ,F
	RETLW 	0X00
COUNT:
	BSF 	STATUS,RP0
	MOVWF 	OPTION_REG
	MOVWF 	TRISA
	BCF 	STATUS,RP0
	BCF 	PORTA,3
	BCF 	PORTA,2
	CLRF 	CNT3
	CLRF 	TMR0
	CLRF 	RTCC2
	BCF 	PORTA,2
	MOVWF 	COUNT1
FR4 MOVLW 	0XFA
	MOVWF 	COUNT2
	GOTO 	FR6
FR5 NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	SUBWF 	RTCC2 ,F
	BTFSS 	STATUS,Z
	GOTO 	FR7
	NOP
	GOTO 	FR8
FR7 BTFSC 	STATUS,C
	INCF 	CNT3 ,F
FR8 MOVWF 	RTCC2
	NOP
	NOP
	NOP
	DECFSZ 	COUNT2 ,F
	GOTO 	FR5
	DECFSZ 	COUNT1 ,F
	GOTO 	FR4
	MOVWF 	CNT2
	BTFSS 	STATUS,C
	GOTO 	FR9
	BTFSS 	STATUS,Z
	INCF 	CNT3 ,F
FR10 DECF 	CNT1 ,F
	BCF 	PORTA,2
	XORWF 	CNT2,W
	BTFSC 	STATUS,Z
	GOTO 	FR10
	RETLW 	0X00
START:
	CLRF 	PORTB
	BSF 	STATUS,RP0
	MOVLW 	B'00010000'
	MOVWF 	TRISA
	MOVLW 	B'00000000'
	MOVWF 	TRISB
	BCF 	STATUS,RP0
	CALL 	INT_DEL
	CALL 	INT_DEL
	CALL 	INT_DEL
	CALL 	MIRROR
	MOVWF 	PORTB
	CALL 	INT_DEL
	BCF 	PORTA,E
	CALL 	INT_DEL
	BCF 	PORTA,E
	CALL 	INT_DEL
	BCF 	PORTA,E
	CALL 	INST
	CALL 	INST
	CALL 	INST
	CALL 	INST
	MOVLW 	0X50 ;P
	CALL 	LCD_OUT
	MOVLW 	0X46 ;F
	CALL 	LCD_OUT
	MOVLW 	0X43 ;C
	CALL 	LCD_OUT
	MOVLW 	0X2D ;-
	CALL 	LCD_OUT
	MOVLW 	0X35 ;5
	CALL 	LCD_OUT
	MOVLW 	0X30 ;0
	CALL 	LCD_OUT
	MOVWF 	COUNT3
WAIT1:
	MOVLW 	0XC8
	MOVWF 	COUNT4
WAIT2:
	CALL 	INT_DEL
	DECFSZ 	COUNT4 ,F
	GOTO 	WAIT2
	DECFSZ 	COUNT3 ,F
	GOTO 	WAIT1
	CALL 	INST
	MOVWF 	GATE
	CALL 	COUNT
	XORWF 	19,W
	BTFSS 	STATUS,Z
	GOTO 	MHZ1
	XORWF 	1A,W
	BTFSC 	STATUS,Z
	GOTO 	KHZ1
	CALL 	INST
	MOVWF 	COUNT1
	MOVWF 	FSR
	XORWF 	INDF,W
	BTFSS 	STATUS,Z
	GOTO 	MHZ3
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	MHZ2
	GOTO 	MHZ4
MHZ3 MOVF 	INDF,W
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	MHZ3
	CALL 	LCD_OUT
	MOVWF 	COUNT1
MHZ5 MOVF 	INDF,W
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	MHZ5
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X4D 			;"M"
	CALL 	LCD_OUT
	MOVLW 	0X48 			;"H"
	CALL 	LCD_OUT
	MOVLW 	0X7A ;"Z"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	GOTO 	MHZ
	MOVWF 	GATE
	CALL 	COUNT
	XORWF 	19,W
	BTFSS 	STATUS,Z
	GOTO 	MHZ1
	SUBWF 	1A,W
	BTFSC 	STATUS,C
	GOTO 	MHZ1
	XORWF 	1A,W
	BTFSS 	STATUS,Z
	GOTO 	KHZ1
	XORWF 	1B,W
	BTFSC 	STATUS,Z
	GOTO 	XKHZ
	CALL 	INST
	MOVWF 	COUNT1
	MOVWF 	FSR
	XORWF 	INDF,W
	BTFSS 	STATUS,Z
	GOTO 	KHZ3
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	KHZ2
	GOTO 	KHZ4
KHZ3 MOVF 	INDF,W
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	KHZ3
	CALL 	LCD_OUT
	CALL 	LCD_OUT
	INCF 	FSR ,F
	MOVF 	INDF,W
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X4B 			;"K"
	CALL 	LCD_OUT
	MOVLW 	0X48 			;"H"
	CALL 	LCD_OUT
	MOVLW 	0X7A 			;"Z"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	GOTO 	KHZ
	MOVWF 	GATE
	CALL 	COUNT
	XORWF 	19,W
	BTFSS 	STATUS,Z
	GOTO 	KHZ
	SUBWF 	1A,W
	BTFSC 	STATUS,C
	GOTO 	KHZ
	XORWF 	1A,W
	BTFSS 	STATUS,Z
	GOTO 	XKHZ1
	XORWF 	1B,W
	BTFSC 	STATUS,Z
	GOTO 	HZ0
XKHZ1:
	CALL 	INST
	MOVWF 	COUNT1
	MOVWF 	FSR
XKHZ2:
	XORWF 	INDF,W
	BTFSS 	STATUS,Z
	GOTO 	XKHZ3
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	XKHZ2
	GOTO 	XKHZ4
XKHZ3:
	MOVF 	INDF,W
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	XKHZ3
XKHZ4:
	MOVLW 	0X2E 			;"."
	CALL 	LCD_OUT
	CALL 	LCD_OUT
	INCF 	FSR ,F
	MOVF 	INDF,W
	CALL 	LCD_OUT
	INCF 	FSR ,F
	MOVF 	INDF,W
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X4B 			;"K"
	CALL 	LCD_OUT
	MOVLW 	0X48 			;"H"
	CALL 	LCD_OUT
	MOVLW 	0X7A 			;"Z"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	GOTO 	XKHZ
	MOVWF	GATE
	CALL 	COUNT
	XORWF 	19,W
	BTFSS 	STATUS,Z
	GOTO 	XKHZ1
	XORWF 	1A,W
	BTFSS 	STATUS,Z
	GOTO 	XKHZ1
	SUBWF 	1B,W
	BTFSC 	STATUS,C
	GOTO 	XKHZ1
	CALL 	INST
	MOVWF 	COUNT1
	MOVWF 	FSR
	XORWF 	INDF,W
	BTFSS 	STATUS,Z
	GOTO 	HZ2
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	HZ1
	GOTO 	HZ3
HZ2 MOVF 	INDF,W
	CALL 	LCD_OUT
	INCF 	FSR ,F
	DECFSZ 	COUNT1 ,F
	GOTO 	HZ2
	CALL 	LCD_OUT
	MOVLW 	0X48 			;"H"
	CALL 	LCD_OUT
	MOVLW 	0X7A 			;"Z"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	MOVLW 	0X20 			;"SPACE"
	CALL 	LCD_OUT
	GOTO 	HZ
OVERFLOW:
	CALL 	INST
	CALL 	INST
	MOVLW 	0X4F 			;"O"
	CALL 	LCD_OUT
	MOVLW 	0X76 			;"V"
	CALL 	LCD_OUT
	MOVLW 	0X65 			;"E"
	CALL 	LCD_OUT
	MOVLW 	0X72 			;"R"
	CALL 	LCD_OUT
	MOVLW 	0X66 			;"F"
	CALL 	LCD_OUT
	MOVLW 	0X6C 			;"L"
	CALL 	LCD_OUT
	MOVLW 	0X6F 			;"O"
	CALL 	LCD_OUT
	MOVLW 	0X77 			;"W"
	CALL 	LCD_OUT
	CALL 	INST
	GOTO 	MHZ
	END
Now she can concentrate on her job
Only changes i made in the config location are
1. _CP _ALL is changed as _CP _OFF and
2. ADDED errorlevel -302
Regards,
Sarma.
mvs sarma is offline   Reply With Quote
Old 6th December 2007, 11:20 AM   (permalink)
Experienced Member
Thanks Sarma..
EDIT:
Hi Dawn,
You say you dont know where the code came from..?
The code seems to work OK.
Looking thru it, I would suggest you hit the delete button, its dreadful.
Eric
PIC tutorials:
Old 6th December 2007, 12:47 PM   (permalink)
Experienced Member
Hey thanks all. With the new code the counter seems to work well enough... using a simple 2MHz Crystal driven Colpitts oscillator (I hope that is the correct name) the counter shows 1.9999917 MHz, does that seem close enough?
Well Thanks all again.
Dawn
Old 6th December 2007, 01:25 PM   (permalink)
Experienced Member
Eric, while I wouldn't use the word elegant, it does work. I must say though, it took me a while to work out what it was doing and where to put that return. The read of the LCD status is particularly confusing.
To be fair, I suspect that it was written for a 12 bit core and so the only way to code it was in line. For anyone not aware of the fact, 12 bit cores had a stack that contained only 2 words.
Maybe we should start a competition. See who can produce the most elegant translation.
Old 6th December 2007, 01:36 PM   (permalink)
Experienced Member
I'll start with the MIRROR routine,
Old,
MIRROR:
                CLRF    TEMP2
                MOVWF   TEMP1
                BTFSC   TEMP1,0
                BSF     TEMP2,7
                BTFSC   TEMP1,1
                BSF     TEMP2,6
                BTFSC   TEMP1,2
                BSF     TEMP2,5
                BTFSC   TEMP1,3
                BSF     TEMP2,4
                BTFSC   TEMP1,4
                BSF     TEMP2,3
                BTFSC   TEMP1,5
                BSF     TEMP2,2
                BTFSC   TEMP1,6
                BSF     TEMP2,1
                BTFSC   TEMP1,7
                BSF     TEMP2,0
                MOVF    TEMP2,W
                RETURN
New,
Mirror		movwf	Temp
		clrf	Answer
		bsf	Answer,0
MirrorLoop	rrf	Temp,F
		rlf	Answer,F
		btfss	STATUS,C
		goto	MirrorLoop
		movfw	Answer
		return
Old 6th December 2007, 01:38 PM   (permalink)
Experienced Member
hi Mike,
It was mainly the LCD coding part that was IMO 'confused'.
As you say. most likely a 'hand me down' from an earlier device.
Shouldn't you be in bed at this time..
Regards
Eric
PIC tutorials:
Old 6th December 2007, 01:41 PM   (permalink)
Experienced Member
It's only 11:30 pm. Still got a few stubbies to sample.
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 09:15 AM
Using Oscilloscopes mechie Electronic Theory 9 29th November 2007 09:48 PM
HD44780 lcd help jay543_uk Micro Controllers 12 8th November 2007 03:26 PM
calculator chinmay7 Micro Controllers 1 14th October 2007 12:45 PM
microchip application A590 /display is ok now prosound90 Micro Controllers 20 18th November 2006 09:44 PM
