+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 27 of 27
Thread: Flyback Transformer Driver Circuit
  1. #16
    Mr. Questions Newbie
    Join Date
    Dec 2007
    Posts
    14
    Quote Originally Posted by audioguru
    Most flyback driver circuits have a trimpot for frequency and a second trimpot for duty-cycle. If the duty-cycle is low then a huge current is for only a moment and the voltage produced by the flyback is very high but the average current heating the Mosfet and drawn from the supply is low.
    So try adding a trimpot for reducing the duty-cycle and add a big capacitor across the little wall-wart's output to store enough power for those momentary high current pulses.
    In the circuit I want to refer to, it uses the 555 timer. I replaced the entire 18K resistor and 50K trimpot with an 100k Trimpot. This reduces the frequency and the Duty cycle at the same time.
  2. #17
    Join Date
    Dec 2007
    Posts
    14
    But really all I want is a 30V couple amp Power supply that can run with this.
  3. #18
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    You need to tune the frequency for power then tune the PWM separately for good efficiency.
  4. #19
    Join Date
    Dec 2007
    Posts
    14
    Yeah, but I don't want to build another circuit for this thing. It works great! All I need is more voltage and more power. 30V and 3 Amps should suffice?
  5. #20
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    Turn up the voltage until either something gets too warm or something gets zapped.
  6. #21
    Join Date
    Dec 2007
    Posts
    14
    What do you suggest then for a Flyback Driver? I was on youtube and I saw the ZVS Driver, so what should I use? You pick, as I just want big sparks!
    Well, I did find this schematic, and I watched a movie with it. It looks really easy. It looks like I may need some high rating parts to do this, but that will be fun finding.
  7. #22
    saturn1bguy Newbie
    Join Date
    Nov 2007
    Location
    Great Salt Lake
    Posts
    354
    LOL
    A great, old credo that still appears to have application :-)
    Corey
  8. #23
    Join Date
    Dec 2007
    Posts
    14
    What kind of wattages would I be looking at for each part?
  9. #24
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,458
    Hi things,
    your circuit looks about right to be applied by my crazy brother in law, who does fishing using fire crackers or electric shock devices. He has already fried six of my design which are more costly. He just dumps the electrodes into water when a fish passes. Dead fish and dead short!
    No problem with that, Thais know everything better!
    The only way out of his dilemma is a new "tickler" for each fish.
    Would you kindly give me info about the primary turns you made on the flyback? That thing has to go from the lab to the field right away!
    Thanks in advance
    Regards
    Boncuk
  10. #25
    Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    I have been following this thread and I ran out and got the part's from my local TV repair guy (IRF540), and it worked great! I added a ferrite Toroid to the end, so it can attract the arc better (since it is affected by magnetism). I was pulling about 1.5 cm sparks out of it easily. The High pitched ring from the coil is very annoying (my classmates loved it ) when it is in the high frequency. I only was feeding 12V at 850ma or something like that, so I also hope to build a large PSU for this.
    Any suggestions?
    IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
  11. #26
    Join Date
    Dec 2007
    Posts
    14
    Where can I aquire such a power supply? I have seen threads of people winding their own, but where can I buy one, or get the parts for one?
    I would like the Voltage supply to be around 40V.
  12. #27
    things Good things Good
    Join Date
    Jan 2007
    Location
    Cairns, Australia
    Posts
    742
    Quote Originally Posted by Boncuk
    Hi things,
    Thanks in advance
    Regards
    Boncuk
    Every flyback will differ, but i just wraped 4 turns of wire straight on the core for the primary, and 2 or 3 for the feedback. The less you have on primary, meas more power, but the transistor gets very hot fast, so i used a biggish heatsink. Overall its a good circuit. Just ask me if you need any more info!
    The 3 laws of science....
    1. If it smells bad, It's chemistry.
    2. If it's mushy, It's biology.
    3. If it doesn't work, It's physics.
    www.laserchat.org IRC chat for laser and electronic related stuff.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Please analyze this circuit.....for energy meter testing
    By tkvenki in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th August 2008, 12:08 PM
  2. need an old flyback transformer
    By PhantomRacer in forum Datasheet/Parts Requests
    Latest: 28th September 2007, 10:50 PM
  3. Mains ground point and circuit ground point
    By Johnson777717 in forum General Electronics Chat
    Latest: 1st September 2007, 10:19 AM
  4. Time Delay Relay Circuit.....is this doable?
    By Draguen in forum General Electronics Chat
    Latest: 31st August 2005, 04:02 PM
  5. precise driving circuit
    By jaikanth in forum General Electronics Chat
    Latest: 10th May 2005, 07:13 PM
Tags for this Thread
