Old 3rd December 2007, 12:00 PM   (permalink)
delta06 is on a distinguished road
Default Inverter Transformer
Need help from all,
I wanted to build a small inverter (50 - 100 W) for my school project, just want to know about the transformer, is it an ordinary transformer that was just connected in reverse? I don't know much about electronics yet, thanks in advance.
delta06 is offline   Reply With Quote
Old 3rd December 2007, 02:38 PM   (permalink)
Experienced Member
mvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to all
Send a message via MSN to mvs sarma Send a message via Yahoo to mvs sarma
If the frequency of the inverter is around 50 or 60Hz, perhaps the ordinary transformers could be used.But , there is a problem. The core saturates with DC flow in the low voltage primary. It is generally overcome by packing the core of the transformer in a special way. All "E"s of the E & I core one one side and all the "I"s on the other side. With a reluctance air gap calculated. this gap can be in the form of Teflon sheeting to meet the required "mills"(=1/1000 of inch is a mill - perhaps you might already know it).
with such arrangement and if the primary wire is thick enough to carry the required current for deliver 50 to 100W on secondary, leaving margins for system efficiency and Power factor and also for square wave vs Sine wave.
Once all the above criteria are met , you will observe the size of the transformer will increase.
On the other hand if high frequency is used, like the modern ones (PWM type), you might need a Ferrite cored Transformer- the size could be reduced if high frequency versions are designed.
Regards,
Sarma.
mvs sarma is online now   Reply With Quote
Circuit Design: Transformer (or Inverter?) jrod5000 Electronic Projects Design/Ideas/Reviews 5 2nd November 2007 04:51 PM
Problems selecting a PCB Transformer NewcastleSAR Datasheet/Parts Requests 31 4th January 2007 07:15 PM
Improving Power inverter Hussein Kkaanya Chit-Chat 2 22nd June 2006 04:41 PM
using a 320W flash with a 150W inverter denoise General Electronics Chat 5 19th February 2006 03:44 PM
inverter or inverter? glmclell General Electronics Chat 1 11th August 2004 12:16 AM
