Old 2nd December 2007, 01:16 AM   (permalink)
Default LM386 Mic Amp to LED Output
Hi all,
I'm trying to build a microphone-driven amplifier outputing to a few low-voltage LEDs. I'm working from a very simple, 9V battery powered design using a single lm386 IC. The circuit design is similar to the "Simple LM386 Audio Amplifier" I found at http://www.techlib.com/electronics/audioamps.html#LM386. I've been experimenting trying to adapt this to drive LEDs, with the main result that I can't seem to get enough power.
As far as I can tell, this should be powerful enough to make a mic signal light up a few low voltage LEDs, but even on full gain I have to make a lot of noise into the mic to get much response.
Suggestions? Do I need more amplification for a direct mic signal?
Laplace's Demon is offline   Reply With Quote
Old 2nd December 2007, 02:44 PM   (permalink)
An LM386 is a low gain small power amplifier, you need a mike preamp to feed it.
Old 2nd December 2007, 03:43 PM   (permalink)
You could use the output of the amplifier to power a transistor which then powers the LEDs.
If you aren't afraid of life then you aren't paying close enough attention.
CynicalMan is offline   Reply With Quote
Old 3rd December 2007, 05:28 AM   (permalink)
The LM386 with the capacitor between pins 1 and 8 has a voltage gain of 200.
A mic has a typical output of 10mV with normal talking so the output of the amp is 2V which will barely light an LED.
If you shout into the mic then the LED should be very bright and will need a series current-limiting resistor.
The circuit that was posted uses a dynamic mic that has a coil and magnet. Maybe an electret mic was used that won't work if it is not powered.
I think the amp should be biased so that direct-coupled LEDs can be used.
I think this circuit might work:
Function Generator output driver evandude General Electronics Chat 6 31st January 2005 07:49 PM
Effects stephenpic Micro Controllers 6 19th January 2004 11:57 AM
VERY low voltage on output pins, please help! New2PIC Micro Controllers 1 18th January 2004 03:21 AM
How do I generate a potentiometer output? klick General Electronics Chat 3 23rd November 2003 02:26 PM
Simple LM386 Amp Help mod_critical Electronic Projects Design/Ideas/Reviews 5 24th May 2003 01:53 AM
