My friend has a portable casette and fm player, he only just found out that his earphone was not functioning so he snip off the war phone piece and strip of the cable. Th cable in it contains 2 wires so heconnect it to a 4 inch speaker and sound is heard but the sound was very soft even at full volume, so what can I use to amplify the sound and make it louder?
I also have a schematic that uses IC as input and 4 transistors as output. this one is very simple and easy to assemble specially if you are new to building amps. I also got this from the web, just forget where just have have to review it. it has 10w output. have tried it and its ok.
\"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~ |
i have a circuitry for a 10w amp using IC as input and transistors as output. i got it from the web but i forgot where, i will just have to check my files. this one i have tried and i could say it was ok.
You can make an amp that can give up to 80W in 4ohm or 50W into 8ohm
with the TDA7294. It only needs a few extra components and is very small (I have made a pcb layout that fits 2 of them (stereo) on a board not bigger then 10 by 4.5 cm) Datasheet on http://home.eunet.cz/rysanek/pdf/tda7294.pdf It plays quite well with the setup displayed on page1 of the datasheet. |
Are you sure this cassette/fm player is only mono, one earpiece ? not stereo headphones?
What do you want to power this amplifier from ? if the mains is available a deafening 80W amp may be what you want... If a tiny battery is all you will have then a 100mW (typical pocket radio volume) would be more realistic.
I need a memory upgrade ... My head is full ! |
Other (less powerfull) compact amps you can use:
TDA1015 (1 - 4 watt) good to run on batteries http://www.semiconductors.philips.co...1015_CNV_2.pdf TDA2003 (up to 10watt) http://www.electronic-kits-and-proje...ts/tda2003.pdf TDA1521 (2x 12Watt stereo) http://www.semiconductors.philips.co...21_Q_CNV_2.pdf |
