Hi, I'm trying to replicate the following circuit diagram, but I can't seem to find any sites/stores that are still selling the ceramic filter that they use (SFZ455F), so I was just wondering if its possible to replace it with some other ceramic filters.
http://www.qsl.net/pa3fdc/tech/hrx80/hrx80r1b.gif And just another question, what does SFZ actually mean? I've tried googling for the datasheet and I just can't seem to find any revelent stuff. Thanks in advance. |
This appears to be an older Murata part number. I looked in their most recent Ceramic filter catalog for North America and don't see it there, probably because they have changed over to marketing mostly SMT packages. I found an alternative at Oscilent.com in their series number 739, see part no. 739-455-HL-C, which seems to be a close alternative.
http://www.oscilent.com/spec_pages/Filters/F-739.html Be sure to check if the package of this part still fits into the circuit board layout, as I did not do that. Otherwise here is a link of a potential supplier of the Murata part: http://www.xs4all.nl/~barendh/Cateng...g_x-filter.htm
RadioRon |
Hi Forever99482,
These are simple old style filters, in/out impedance 3k. The "F" stands for 12 kHz bandwidth. (+/- 6 kHz.) They usually come in pairs or triples but sometimes also single. The orange one's are two three pin filters glued together. A possible substitute could be a SFD455F from Murata, that's the red one. It actually has five pins, only one ground pin. It contains two SFZ455F's in one package. No matter what you do stick to the 3k in/out impedance. The 455 kHz center frequency is not critical in this design, you can replace them with 450 or 460 kHz filters. on1aag. Last edited by on1aag; 28th November 2007 at 05:32 AM. |
(permalink) | ||
Thanks for the given information, it was very useful.
Can anyone find a datasheet on the SFZxxxF series? |
possible that you get this item locally
Regards, Sarma. Last edited by mvs sarma; 7th July 2008 at 10:22 AM. |
circuit diagram: http://www.qsl.net/pa3fdc/tech/hrx80/hrx80r1b.gif Thanks. |
How ever it is many years since we stoped dreaming for TCA440 as it was not available in our country. After so long time you have shown a schematic. but I fear that this item will be in short supply or unduely priced.
Regards, Sarma. Last edited by mvs sarma; 28th November 2007 at 06:43 PM. |
The selectivity of the filters is chosen to suit the bandwidth of the signal that you are receiving. This receiver project appears to be designed for radio direction finding, being an SSB receiver set up to receive LSB on 80 meters. For SSB, it is typical to choose filters for a cascaded response providing about 2.4 to 3 KHz overall bandwidth. When researching alternate filters, I found that the AM filters available are often quite wide, so I chose the narrowest model, the 739-455-HL-C. This part has a spec BW of 4 KHz at -3dB, so when two of these are cascaded, the net response is likely to be close to 3 KHz. Of course, you can choose any bandwidth you want from the Murata lineup, but I recommend going with something around 3.5 to 4.5 Khz per filter, or even a bit narrower is OK.
The impedance of the filter will affect the efficiency of the match to the 440 IC, but this is not a highly critical match. Note that there is a 3.3 Kohm resistor right beside each filter. If you change this value to be the same as the filter impedance, that is about all you need to do.
RadioRon |
Hi Forever99482,
These filters are really cheap stuff. It is also difficult to tell what the bandwidth is because I don't know if a single or a multiple unit is used. Say you have a 15 kHz (-6dB) wide filter and you add another one, the bandwidth of the combined filter will be reduced to let's say 12 kHz (-6dB) and the flanks of the filter will become steeper too. You could lower the resistance values at pins 7 and 15 to match the new filters but the gain of these stages will also be reduced with the same amount. However pin 15 is a whole new ball game, it's an input with an internal 3 k resistor. Of course it can be matched too but you could use a battery charger as a receiver as well. So stick to the single resonator filters with their 3k in/out impedance and don't worry too much about the bandwith of the filters. You can always add some more if you like. http://www.toko.co.jp/products/en/fi...ndex_am_e.html http://www.alldatasheet.com/datashee...NS/TCA440.html http://www.xs4all.nl/~barendh/Indexeng.htm on1aag. |
will probably be about right. And if you find that the IF bandwidth is a bit wide, you can always add an extra filter because their in/out impedance is 3 k. But I wouldn't make the IF bandwidth too narrow because the design has a manual tuning. on1aag. |
hmm...... I seem to have trouble finding a company (like farnell, or rswww) that provides this sort of filter, could you please direct me to some site that sells it?
Thanks. |
RS Components has a branch at Malaysia Ps: heregoes malaysia link RS Web Helpline: 603 5032 7633 or onlinehelp.MY@rs-components.com
Regards, Sarma. Last edited by mvs sarma; 30th November 2007 at 08:57 AM. |
![]() Could someone please tell me why there is a capacitor in between the ceramic filters, SFZ455F (both 47pF)? If I change the SFZ series to a CFA series from toko, do I need to change the value of the capacitor? Thanks. |
F1 and F2 are sets of filters coupled by a capacitor. F3 is individual single , but used for oscillation at 455KHz.
You could imagine 2 numbers each of SFZ455F at locations of F1 and F2. Earlier, there used to be single filter with 6 pins with a provision for external coupling capacitor . Perhaps they may be available now too. Toko Ceramic filters you have selected are too broad like 13+/-3 KHz while sfz455F series are narrow. Whether it would serve your needs ? This replacement amounts that the second part of the filter is not there and thus no need for 47pF.
Regards, Sarma. Last edited by mvs sarma; 3rd December 2007 at 06:02 AM. |
| filters? | Chris_P | Electronic Projects Design/Ideas/Reviews | 13 | 30th July 2007 05:16 AM |
| Ceramic Capacitor VS. Metal Polyester | Omar.M | General Electronics Chat | 3 | 8th April 2007 02:42 AM |
| READING CERAMIC CAPACITORS??????? | BABYBASS210 | General Electronics Chat | 5 | 16th May 2003 07:44 AM |
| controlling band-pass filters | aidanbre | Micro Controllers | 4 | 15th April 2003 07:32 AM |
| band pass filters | aidanbre | Electronic Projects Design/Ideas/Reviews | 1 | 29th November 2002 06:43 AM |
