+ Reply to Thread
Results 1 to 9 of 9
Thread: DC to 1GHz Probe Construction Plans
  1. #1
    insight Newbie
    Join Date
    Nov 2007
    Posts
    12
    Default DC to 1GHz Probe Construction Plans
    Has anyone tried this:
    cheers, dejan
  2. #2
    ronsimpson Good ronsimpson Good ronsimpson Good
    Join Date
    Apr 2007
    Location
    Loveland, CO USA
    Posts
    710
    I made something like this that worked well on a 500mhz scope where 10:1 probes did not work.
    In this project you are to make a 50ohm terminator. I just bought one.
  3. #3
    RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent
    Join Date
    Oct 2005
    Location
    BC, Canada
    Posts
    1,448
    Blog Entries
    1
    I've built several versions of something similar, but a bit cruder and have used them up to 2 GHz for crude measurments with good results. The basic principle of this is sound, and the construction method looks OK. The ones that I've built before used 0402 sized components soldered to the end of a piece of coax and then were glued into a pen barrel along with a gold plated tip pulled from a BNC connector. Same basic idea, but I built both with and without the 50ohm termination and both functioned. In principle, the 50 ohm resistance is a better idea as it provides a correct termination for any reflections coming back from the instrument.
    In using such a thing, it is important to realize that this is effectively a voltage probe. So, if you are using it with a spectrum analyzer that displays power, not voltage, you have to translate in your head using the known or guessed impedance at the point you are probing (Alternatively, some analyzers allow you to display voltage directly). If probing a circuit node that you know is 50 ohms, then this is easy, but if you can't estimate the node impedance of the point you are probing, then your guess about the accuracy of the displayed level will have greater error.
    RadioRon
  4. #4
    insight Newbie
    Join Date
    Nov 2007
    Posts
    12
    Guys, thanks for the reply.
    What is terminator?
    regards,
    dejan
  5. #5
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,775
    Quote Originally Posted by insight
    What is terminator?
    It's a humanoid robot from the future in a series of films
  6. #6
    JimB Excellent JimB Excellent JimB Excellent JimB Excellent JimB Excellent JimB Excellent
    Join Date
    Sep 2004
    Location
    Peterhead, Scotland
    Posts
    1,943
    What is terminator?
    A big guy from the future who has come back in time to kill someone.
    Seriously, transmission lines such as coax cables etc have a characteristic impedance, if the end of a long cable does not have a resistor across it whose value is equal to the characteristic impedance of the cable, there will be reflections from the end of the cable.
    The resistor on the end of the cable is called the terminating resistor, or just terminator.
  7. #7
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,454
    What is terminator?
    I know who is terminator. He is now governator of California.
  8. #8
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    Is a "governator" something like a dictator? A King?
  9. #9
    Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent
    Join Date
    Mar 2006
    Location
    Michigan, USA (GMT-5)
    Posts
    2,892
    Quote Originally Posted by audioguru
    Those were the fly-ball kind on steam engines.
    AND
    I believe that a diode is a poem about death.
+ Reply to Thread
  1. Using Oscilloscopes
    By mechie in forum Electronic Theory
    Latest: 29th November 2007, 09:49 PM
Tags for this Thread
