Old 27th November 2007, 04:59 AM   (permalink)
Red face 7 segment LED counter
I have purchased and bread boardedd a circuit which is made up of 74ls90, BCD counter, 74ls47 seven segment display driver, and some 470 ohm resistors, and 7 segment common cathode displays made by Kingbright. I found this circuit on Aaroncake.net /circuits/counter.asp. I already have over $140 invested in this. I get the numbers to come up but they are random, and sometimes I get random letters. This circuit is to replace a shuffle board game that had 2 PC boards wiped out by 110 volts.
I need some help in getting this thing to work properly, so I can press on with getting the shuffle board back on line.
I hoped this is the way to get this problem out there.
Tom
ttebeau is offline
Old 27th November 2007, 05:07 AM   (permalink)
The 74LS series of ICs were used in the seventies. 32 years ago!
Like any counter, they count every bounce of the contacts of a switch, pushbutton or relay. The contacts bounce many times per push.
Look in Google for a Debounce circuit.
None of Aaron's circuits have a very important supply bypass capacitor. Most old 74LS ICs need a 0.1uF ceramic disc supply bypass capacitor each.
audioguru is offline
Old 27th November 2007, 05:17 AM   (permalink)
The first error I see is that you stated the displays are common cathode. The74LS47 is to drive common anode displalys. The circuit shown will come on with a random number showing because the 74LS90 is not reset to 0 on the application of power.
What circuit are you using to trigger the counter? It must be bounce free and TTL compatible.
k7elp60 is offline
Old 27th November 2007, 08:58 AM   (permalink)
Audioguru and k7elp60 have already answered your question. I'm just going to expand on that a bit:
That circuit as posted is just a basic textbook-style outline--it doesn't contain everything you need to actually make it work properly in the real world. If you search this site you will find a lot of other people have had trouble with it for just that reason.
o You need a bypass capacitor on the power pins to get rid of power-supply spikes caused when the counter counts. Otherwise the thing can get false input triggers. Check page 554 in the Art of Electronics for more information.
o You really do need a debounce circuit on the input--even a good switch will make and break contact several times over the first millisecond or so after being switched before it settles down. A debouncer just turns this into one nice transition from On to Off (or vice versa). Read this thread for more information and instructions on how to do it.
o When you turn the counter chip on, its state at the moment after power is applied is undefined unless you give it a reason to reset to 0. Check out this thread for more information. In particular, the second-to-last post in the thread (by Sebi) shows how to wire it a power-on reset circuit to the 74LS90.
Hope at least the links help. I found them (and this board) very helpful when working on my foosball table last year. I keep meaning to clean up my finished schematic and post it with some pictures.
Good luck!
Torben
Torben is offline
7 segment LED counter shihabva Electronic Projects Design/Ideas/Reviews 0 29th September 2007 04:23 PM
HELP Needed!! - 7 Segment LED counter (74LS90 TTL) kwon Electronic Projects Design/Ideas/Reviews 11 16th August 2007 02:52 PM
driving multiplexed 7 segment display mathur2000 Micro Controllers 7 24th June 2007 11:08 PM
How we can do it in Assembly..Help Needed Ayne Micro Controllers 37 29th December 2006 06:49 PM
7 Segment Counter SCJohnson77 General Electronics Chat 5 29th August 2006 02:32 AM
