Old 25th November 2007, 10:52 PM   (permalink)
Default Line Follower robot (LDR)
Hello guys.
I know that most line following robots use photodiodes or phototransistor or IR recievers.
I wanted to know if using LDR it could work.
The schematic attached is the circuit I'm thinking to use for each receiver.
And maybe instead of connecting directly to the motor I could connect to a comparator first.
What you say about it?
The best e-book
Voltboy is offline
Old 25th November 2007, 11:36 PM   (permalink)
I think more line follower sensors use IR - visible light can interfere with your LDR. The IR sensors typically have a visible light filter.
I've used phototransistors to good effect. Cheap and very easy to interface to a microcontroller.
How exactly is your line follower going to work if the sensors drive the motors? seems a lot harder than using a microcontroller.
philba is offline
Old 26th November 2007, 12:27 AM   (permalink)
Well the circuit withe the LDR works very simple. The motor speed is proportional to the light over the LDR. So if lets say the line is reflecting light to the LDR one side will go fast and the other motor (assuming its a curve) will be off because of darkness.
The best e-book
Voltboy is offline
Old 26th November 2007, 09:21 PM   (permalink)
in theory. if it works the way you expect, what's to prevent over shoot? I suspect that if it works at all, you will get oscillation.
What happens when neither sensor is over the line? Lets also not forget external light interference.
A good line follower uses more than 2 sensors.
philba is offline
Old 26th November 2007, 09:23 PM   (permalink)
Yes I know that, it was only supposing, i got about 10 LDR's
The best e-book
Voltboy is offline
line follower robot schema kelso00 Robotics Chat 20 11th August 2008 12:40 AM
line follower robot program UnD3aD Robotics Chat 2 23rd October 2007 08:13 AM
Line Follower Robot using Logic Gates Flipsyde412 Robotics Chat 3 4th May 2007 12:00 AM
need help about line follower robot ther12k Robotics Chat 0 25th April 2007 04:15 PM
Line Follower robot Khai9477 Robotics Chat 1 22nd February 2007 09:40 AM
