Old 25th November 2007, 12:33 AM   (permalink)
Default How do I suspend output?
Hi, new here and to the world of electronic design.
I have made a circuit that will bring on the signal lights of my bike at a reduced voltage for running lights. I used a 555 timer as a PWM. It all works as intended except that I would like it to shut off when the signal lights are on. Also I would like it to stay off for a period of 700ms and then resume operation. the entire circuit is on the hi side of the sig. light so there is no ground signal on the board. Any thoughts of how this could be done would be apreciated.
Earl
PS; I am trying to keep this as simple as possiple, I would like to utalize the 12v back feed that will be present when the sig. light is flashing as the trig. to shut down the timer. I would also like it to remain off for the full period of the cycle of the sig. lights, 680ms(340ms on, 340ms off)
Can I trig pin 2 hi and then let it go low through a RC circuit ?
BigAdv is offline
Old 25th November 2007, 12:47 AM   (permalink)
Please provide a schematic.
You can take pin 4 low, if it's an astable but without a chematic it's difficult to know.
Screen name: Aloone_Jonez
Hero999 is offline
Old 25th November 2007, 12:50 AM   (permalink)
Do you have a schematic (Diagram) that we can look at?
shaneshane1 is offline
Old 25th November 2007, 12:51 AM   (permalink)
Whoops, must have sent at same time.
Old 25th November 2007, 02:16 AM   (permalink)
Ill try to post the diag. Also I would like to use the 12v feedback from the sig. lights to shut off the timer.
Also note that the fet on the diag. is wrong, its not a dual gate, but this was the only thing close that I had the time to find.
BigAdv is offline
Old 25th November 2007, 12:18 PM   (permalink)
Just connecting pin 4 to +V via a pull-up resister and connecting it to 0V when youy want to turn it off should do the job.
Hero999 is offline
Old 25th November 2007, 09:24 PM   (permalink)
Yes that would work, but I do not have a ground, and I would like to utilize the hi sig. from the sig. light as the trigger. I am a n00b when it comes to this stuff, so a detaled description or diagram would be usefull
Earl
BigAdv is offline
Old 27th November 2007, 01:16 AM   (permalink)
You will have ground on pin 1 of the 555, if you pull pin 4 high with a resistor like Hero999 suggested a transistor between pin 4 and pin 1 should work if I am understanding you correctly.
Use the high signal from the signal light to trigger the transistor.
Brevor is offline
Old 28th November 2007, 09:34 PM   (permalink)
Alright then, do it the other way round, tie pin 4 to pin 1 with a pull down resistor then connect it to +V when you want to turn it on.
Hero999 is offline
Trailer Electrical Wires daviddoria General Electronics Chat 9 3rd November 2007 09:13 AM
Line Detection Robot using PIC16F877 helmyshahryl Micro Controllers 0 28th August 2007 02:54 AM
Pic Basic Pro / PIC Problem Tako Kichi Micro Controllers 7 11th January 2004 11:46 PM
Turn on and off air valves thup Electronic Projects Design/Ideas/Reviews 16 27th December 2003 04:19 AM
brake light/ turn signal andrew8485 Electronic Projects Design/Ideas/Reviews 13 11th November 2003 01:49 AM
