Old 22nd September 2003, 08:59 AM   #1
Default Time/delay circuit
I know this is something simple but i've done a little searching and can't find what i'm looking for and it's been a while since digital logic courses, but i can't work it up form scratch for the life of me....
I'm looking for digital logic circuit/gate that everything starts at 0 (low) and then if high is input, the output is high, but only for about 5 seconds, then the output goes low again, nomatter if the input stays high or goes low again.
I hope i explained it clearly, but basically the effect would be, press a button to turn on a LED or something for 5 seconds or so, if you hold the button down it goes for 5 seconds and turns off, if you press it and let go it will hold it for 5 seconds and turn off, either way once the led goes low it is ready to be turned on again.
bonanz
bonanz is offline
Old 22nd September 2003, 02:49 PM   #2
Try looking for a 555 tutorial and you will find the circuit you need. As a hint try Monostable 555 circuit 8)
Ivancho
ivancho is offline
Old 18th October 2003, 06:06 PM   #3
i need help to find a circuit :
set/reset circuit by presing one boton
luis ferreira is offline
Old 19th October 2003, 02:46 AM   #4
Hi Luis,
Sounds like you mean a flip-flop circuit.
John
john1 is offline
Old 19th October 2003, 09:05 AM   #5
See this circuit:
Time/delay circuit-on_off_153.gif
Sebi is offline
Old 24th October 2003, 08:30 PM   #6
im sorry the time
not a flip flop circuit but impulse relay circuit with one boton
i send a picture with a circuit like i want but this have two switches
Old 25th October 2003, 03:31 PM   #7
Just a small modification for relay...
Time/delay circuit-on_offrelay.gif
Sebi is offline
Old 27th October 2003, 01:59 PM   #8
thanks Sebi your circuit works very well.
