Old 18th November 2007, 06:15 AM   (permalink)
Default Need Help w/ Digital Audio Switch Circuit (SPDIF/COAX)
Hello,
My knowledge level on electrical circuits could be classified as novice at best.
I have a receiver with 2 digital inputs, 1 optical 1 coaxial, and 3 devices to connect, 1 optical 2 coaxial. I need to build a circuit to switch between the 2 coaxial input devices. The motivation here is to avoid purchasing a new receiver.
I already have the following IR controlled switch:
http://www.vellemanusa.com/us/enu/pr...iew/?id=500341
This switch uses an IR signal (from my Harmony remote) to control a pair of SPST relays, in either pulse or toggle mode. It takes a 12vdc input from a regular old universal adapter. One relay is currently controlling a pair of 120mm fans which ventilate my entertainment cabinet when the xbox360 is running. The second relay will be used as a remote power switch for a home theater PC.
The xbox and the HTPC will be the 2 audio input devices that need to be switched (i'm purchasing a Optical/Coax converter for the xbox, the htpc already has a coax out).
My initial thought is to use the fan control relay to also control a separate DPDT relay to switch between the audio inputs. In this case the normally open terminals would connect to the xbox, and normally closed to the HTPC. Since the fans are only running when the xbox is on, the circuit would 'default' to the HTPC, but switch to the xbox when the fans came on.
This is the best solution I could come up with using my minimal knowledge. Since this is an audio signal, though digital, is the relay the right approach or is there a better and similarly inexpensive way to go?
Your suggestions and comments are very much appreciated. Thanks!
- jdm623
jdm623 is offline   Reply With Quote
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 01:45 PM
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 02:44 PM
UV flame scanner bulb/tilt switch used as safety-need circuit help Rezaxis Electronic Projects Design/Ideas/Reviews 2 28th August 2006 01:52 AM
DIGITAL MODULATOR CIRCUIT TDE Electronic Projects Design/Ideas/Reviews 3 19th January 2003 02:51 AM
wireless circuit for a digital cam blackdrongo Electronic Projects Design/Ideas/Reviews 1 12th December 2002 09:58 AM
