Old 17th November 2007, 03:11 PM   (permalink)
Default How to power a fan
Hoping someone can help me with this issue. I have two cats and I purchased a "Cat Furniture" litter box for them. It will be placed in the garage with a pet door from the house leading to it. I want to pull the litter box air out of the furniture box and vent it to the garage. I bought two Nexus fans per the following specs:
Nexus Real Silent 120 mm Case Fan Specifications
Model D12SL-12
Power Connector 4-pin & 3-pin
Dimensions 120x120x25mm
Rated Voltage 12 Volts
Operation Voltage 6.5 ~ 13.8 Volts
Input Current 0.30 Amp Max
Input Power 1.8 Watts Max
Can anyone tell me what I need to do to supply power for one of them or both of them at the same time. I know I need a small ac/dc power supply but I don't know what size or type. Also; how do I hook up the power. The connectors are listed above. The fan is for a computer but I purchased it because it is very quiet. Didn't think that the cats would like to hear a lot of fan noise while they are doing their business.
Any assistance would be appreciated.
Thank you!
Fourcorners is offline
Old 17th November 2007, 04:13 PM   (permalink)
I'd probobly give it 12v at 1 watt(for 1 fan), I don't know how to connect power to the "4 pin connector" are ther any pinouts?
(You can use algebra to figure Amps)
wmmullaney is offline
Old 17th November 2007, 05:10 PM   (permalink)
Thank you!
Maybe, just maybe, you can teach the cat to cut it's claws on the fan blades, but you better make sure he's not just sharpening them!
Idea: You could have one fan running all the time and the second one controlled by a motion sensor so that it turns on as he gets in the box.
Also, the fans are capable of speed adjustment so connecting a pot in line with them will allow for precise control.
Attached is a drawing of the connector you probable have. The easiest way is to cut the connectors off all together and wire it that way... +(positive) supply to yellow and ground to black. The red wire is a sense wire for speed variation relative to heat when hooked up to your motherboard. The option 2 cut is if you are certain you have the matching three pin connector. The 2 fans should be able to run from the same 12VDC 1000mA supply.
My friend has a similar setup with a motion sensor turning the fan on with a 555 timer for 15min or so, then shutting off.
If your cat is really smelly then I suggest using both fans on high 24/7!
iONic is offline
Computer power supplies - How do I get power out of them? moody07747 General Electronics Chat 3 20th July 2007 09:56 AM
Ultra low power power supply steevke Electronic Projects Design/Ideas/Reviews 1 3rd February 2006 03:46 AM
Power Supply for a project to be powered within an Auto? hexibot43 General Electronics Chat 16 8th September 2005 02:35 PM
Power supply: Fusing to protect circuit Johnson777717 Electronic Projects Design/Ideas/Reviews 4 10th April 2004 02:19 AM
interesting thing-other types of electric power bogdanfirst Electronic Projects Design/Ideas/Reviews 4 16th March 2003 07:08 PM
