hi ya all i want to put my mp3 player in my car and supply it a constant voltage of 1.5v (it consumes very small amount of ampere). how can i build a circuit that will give me a voltage of 1.5 DC out of the car's battery 12v (the actual voltage is between 12-13.8) DC? tnx and good day | |
Whatever circuit you decid to use, be sure to use a fuse!
National Semiconductor / Fairchild do an SOT-23 sized 1.5 volt LDO and they are pretty cheap. Your MP3 should run fine off 1.2v so use two diodes and a resistor for a really simple regulator.
As Ferez has indicated it s consumption is LOW, the best thing is to leave it on its battery and make best use of its portability, rather thanrisking all these trials. If ore power is needed better to adopt a D cell by external implementation and it will be stomach full for a month , i suppose.
| | #6 | |
| | #7 | |
| | #8 |
hi guys, first of all i want to thank ya'all for the answers. second thing, the MP3 player can't be feed through a regular battery because it will be molded\glued to my dashboard (i need to make it look like a built-in gadget in the dash). so, what is the best solution? the LM317? | |
| | #9 |
A remote battery holder. A simple power supply may not provide isolation from electrical noise etc. | |
| | #11 |
adopt a cellphone charger with 5v output from the car battery- then use aa LM317 adj pin grounded and you will get 1.2v volts output. mostly, this is sufficient for the mp3 player. first make dummy load trial outside and then use it for the regular device.
| | #12 | |
| | #13 |
sorry for the stupid question but, how do i make a dummy load? what is the dummy load consists of?
| | #14 | |
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #15 | |
Try putting one red LED with a series resistor of say 82 to 100 ohms and connect across the common ground and +3.3V output. this will work as artificial load (so called dummy load) . Artificial load could also be a 150 resistor but you won't know unless you measure. In the other case, the LED glows. how ever you can calculete the resistor value to suite 70% of maximum permitted current for the RED LED.generally Red LED drops 1.4V across it in the forward direction thus series resistor would be (3.3-1.4)/permitted current for the LED.
| 12v, 15v, coverter |
| 12V Halogen off batteries | Pax Writer | General Electronics Chat | 13 | 6th November 2007 05:06 PM |
| 12V 35AH Solar Battery Charger Question | iONic | Electronic Projects Design/Ideas/Reviews | 9 | 1st November 2007 04:11 PM |
| can a 1.5 button battery be used in a normal 1.5v LED flasher project | dih | General Electronics Chat | 13 | 22nd October 2007 08:16 PM |
| Stepping down 24v to 12v for stepping actuator | gints | Electronic Projects Design/Ideas/Reviews | 4 | 20th September 2007 03:37 PM |
| How to get 1.5v from 9v? | Axe_Murderer | General Electronics Chat | 3 | 17th November 2003 02:35 PM |
