Hello all,
I am trying to build a 12V Lead-Acid Trickle Charger, but with some added features. I'd like a green power on LED and an LED way to monitor the Current drawn. For example: 1 LED for 20mA, 2 LED's for 40mA, 3 LED's for 80mA, 4 LED's for 160mA, and 5 LED's for 320mA or higher. Actually it might be better to only have 1 of 5 LED's on at any given time. |
For the current LED indicator I would suggest a low value resistor in the low side of the charger rail. An opa across the resistor, the output of the opa driving a LM3914 and LEDs, either in dot/bar mode. Do you need a hand with the design? EDIT: this could one way to do it.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:22 AM. |
Would this affect the voltage requirments from the transformer(Wall-Wart)?? |
If you allow about 10mA/LED that should cover the major part of the extra current required. I would estimate that if the existing wall wart is say, 500/100mA, it should be OK. You could set the LM3914 for 'dot' mode, thats one LED at 10mA!
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 05:16 PM |
| Lead acid battery charger Circuit | dimper129 | General Electronics Chat | 14 | 22nd March 2007 02:34 AM |
| Solar powered lead acid battery charger plus Inverter | Raj Lalvani | Electronic Projects Design/Ideas/Reviews | 4 | 13th March 2007 06:12 PM |
| Lead Acid Battery Charger Help Request | jagzviruz | Electronic Projects Design/Ideas/Reviews | 17 | 16th January 2007 10:46 AM |
| 12v Sealed lead acid battery charger | andi_n2004 | Electronic Projects Design/Ideas/Reviews | 1 | 27th April 2004 12:51 PM |
