Old 12th November 2007, 10:08 PM   #1
Default 2 Pics - 1 LCD
does anyone have any suggestions how I can interface 2 pic's to one lcd. Through software, i can make it where only one pic will try to communicate with the LCD at a time. However, when i wire both pics to the LCD, neither pic is able to communicate. Can i simply use an OR gate? perhaps a 3rd pic configured to act like an OR gate?
all suggestions welcome.
hunt4it44 is offline
Old 12th November 2007, 10:16 PM   #2
Use a Mux Unit, .............
JD
JD1 is offline
Old 12th November 2007, 10:17 PM   #3
Having more then one uC talk to a single LCD is difficult.
Better to have one PIC control the LCD. Have the 2nd, (3rd..) PIC send the info to be displayed to the first who then displays the needed info.
How you do the communication is up to you. Lots of options.
The same question was asked here not too long ago. Search for it if you want to read the entire thread.
3v0 is offline
Old 13th November 2007, 03:47 AM   #4
Default thanks
thanks for the response. i guess i need to see what i can do about passing data from one pic to the other which will control the lcd.
Old 13th November 2007, 09:37 AM   #5
You just need a single pin on each, and send serial data - you can even buy serial LCD modules, these just have an on-board PIC doing the processing.
Old 14th November 2007, 05:18 AM   #6
How about using 2 PIC in master slave configuration. the master connect direct to the LCD. The slave can pass on message in 4 bit mode to the master and the master then display to the LCD.
May the force be with you.
My project: Simple White Line Follower
http://au.youtube.com/watch?v=8Z_MmrdH4oc
http://i271.photobucket.com/albums/j...nefollower.jpg
Wingmax is offline
Old 14th November 2007, 11:40 AM   #7
Too bad we don't know what controller is on the LCD.
If it's the well known () Hitachi HD44780.
Then you could buy a 4 lines * 40 characters LCD.
It has 2 controllers on it one for the first two lines and the other for the last two lines.
Such LCD has 2 enable lines (one for each PIC) and multiplexed datalines (to both PIC's).
mcs51mc is offline
lcd, pics
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 10:20 AM
Newbie needs help with LCD backlight dimming Mongoose General Electronics Chat 6 22nd September 2007 12:23 AM
Nokia 7110 LCD + questions regarding code and behaviour of LCD. MrNobody Micro Controllers 2 19th September 2007 08:50 AM
LCD Troubles Kyle-s4h Micro Controllers 13 11th September 2007 01:30 PM
I am interested in PiCs but dont know much about them cubdh23 Micro Controllers 2 10th July 2004 08:07 AM
