How much voltage do you need to power a 6 foot neon light tube that has an inner diameter of 3/8 inch? Does the tube have to be glass?
The voltage will depend on the gas used. The tube must be gas tight.
So it's possible to use material other than glass. I just want the approximate voltage range. Say I'm using neon. Do you have any good links that explain how a neon light is built and how it works?
How about aluminum or copper? |
A 12V battery could light power the light, right? How much power does a neon light use? Say it uses 60mA.
A 6 foot long, 3/8th inch doameter tube would be about 30W.
Uncle $crooge |
No, I wasn't thinking about the little fluorescent tube to light cars. I was thinking of my own invention. I think a plain voltage stepup circuit is called a transformer. An inverse rectifier is an inverter. They are usually used together. 30W is too much. Nevermind.
A car uses an inverter circuit to make AC that is stepped up to a high voltage with a transformer.
Uncle $crooge Last edited by audioguru; 10th November 2007 at 01:32 AM. |
You're correct...
| Tube? | hjl4 | Electronic Projects Design/Ideas/Reviews | 3 | 2nd February 2007 01:39 AM |
| Problem with Neon underbody lights and car dome light | rvk2 | General Electronics Chat | 4 | 3rd January 2007 07:22 PM |
| Cold Cathode Tube help.. | ballpoint | Electronic Projects Design/Ideas/Reviews | 5 | 14th August 2006 03:53 AM |
| Amplifier Hum due to Vacuum Tube failure?? | Rustydawg | General Electronics Chat | 14 | 4th March 2006 08:50 AM |
| fluoro tube holder?? 15watt... | SkinnyBoy | General Electronics Chat | 3 | 21st August 2005 01:14 AM |
