Old 9th November 2007, 11:07 AM   #1
Question Spark detector
I have a small transformer, it will generate high voltage, using voltage doubler (Diode + cap), the voltage is about 1.5~2KV DC. the circuit is similar to neg ion generator, where voltage is high but current is very small.
The application is to test insulated of magnet wire, high voltage is applied to the wire and conductive brush, if insulated of wire is bad, it will sparking.
Now I need to detect if the HV is short or sparking , how to convert the spark or short to logic, so I can interface it to PIC MCU?
Thank you,
VictorPS is offline
Old 9th November 2007, 11:35 AM   #2
I suggest that you put a resistor in series with the HV supply and measure the current.
When there is no spark, there will be no current and no volts across the resistor.
When there is a spark, current will flow and there will be some volt drop across the resistor.
If you put the resistor in the earthy end of your high voltage circuit, interfacing to the PIC should be easy.
JimB is offline
Old 9th November 2007, 11:38 AM   #3
Assuming there is not some constant corona discharge, when it sparts, you should see a voltage pulse or drop. Rather than dealing with the HV side, how about looking across the transformer primary for a current surge with each spark as the circuit recharges? For example, I can monitor a capacitor discharge ignition by looking at the supply line currents. Also, assuming you have some sort of transistor oscillator driving the transformer, I have found with CDI ignitions that you can detect the spark by looking at voltages on the collector or base of the transistor oscillator. John
jpanhalt is online now
Old 9th November 2007, 12:58 PM   #4
Yes, I will give this a try, it shall work too.
My idea is to connect a 103 cap---> resistor --->3.6V /5.1V Zener diodes --> Gnd.
When there is High voltage, I see a logic high, when spark, I may be see a logic 0. However, I have not try yet.
VictorPS is offline
Old 9th November 2007, 01:02 PM   #5
Thanks John, this possible too, may be I need an adc in MCU to detect the small change, as the transformer use is a small one...
Advantage is I can detect short circuit, so can give alarm or shutdown the HV for a while.
VictorPS is offline
Old 9th November 2007, 02:02 PM   #6
Victor,
I think you are on the right path. Here is a typical way used in CRT monitors to monitor high voltage current. With low current the 1K resistor pulls the sense point to 3.3 volts (or 5 volts). Current causes the sense point to drop. –0.7 is the low point. Choose the resistor for the correct current.
ron
ronsimpson is offline
Old 9th November 2007, 05:55 PM   #7
hi Victor,
I suspect you will not see a logical '0' across a zener, you may need say, a 10k resistor in parallel with the 5V1Z zener.
ericgibbs is offline
detector, spark
infrared detector of unknown spec and origin kelangfei General Electronics Chat 1 2nd May 2007 01:07 PM
HID ballast/LCD projector switching spark gap symptoms linuxglobal General Electronics Chat 5 1st April 2006 07:17 AM
Envelope Detector ThermalRunaway General Electronics Chat 13 30th July 2005 07:25 PM
RF Detector/ Mobile detector CircuitMan Electronic Projects Design/Ideas/Reviews 12 27th October 2004 04:39 PM
Looking for a schematic for a spark generator kev*.avr Electronic Projects Design/Ideas/Reviews 5 16th October 2003 10:24 AM
