| New Member | HI I have an op amp feeding the input of an ADC. this ADC must only have 0v to +2.5v on its input. So My Question is How do I clamp the output of the op amp to strictly and only 0 to +2.5 vlolts in order to protect the input of the ADC. The supply of the op amp is -12v and +12v and so far in my practical circuit the output of the Op amp seems to drift outside of these limits. (but that is another question) can anyone help thanks david |
| Experienced Member | Did you try having a rail to rail opamp with supply voltages of 2.5 and 0 V? I can't think of any cheaper solutions that might solve your problem |
| Experienced Member | Do you need the full resolution of the ADC? If not, design your ckt so your signal will only fluctuate between 0.5V and 2V. Use a 2.5V zener diode in parallel with a schottky just to protect the input pin. Your ckt will then operate normally from .5V to 2V and in case anything goes wrong, the voltage at the input pin won't exceed -0.3V/2.5V (or thereabouts). |
| Experienced Member | Quote:
__________________ Measurement changes behavior | |
| Super Moderator | What is your ADC?, if it's a PIC they have protection diodes, and a simple series resistor feeding the pin is all that's required (check my PIC tutorial hardware). If it's not a PIC, and it doesn't have internal protection, simply add external protection diodes, and use a similar series resistor. |
| New Member | could I add an lm358 with a 0 to 2.5+v supply to the output stage? |
| New Member | Er yes, Least significant bits are hard to come by: i need full scale resolution dazza000 |
| New Member | Quote:
dazza | |
| New Member | Quote:
dazza. | |
Its max output voltage is about 1.2V less than its positive supply voltage. Its max input voltage is about 1.5V less than its positive supply voltage.
| New Member | Quote:
dazza. | |
| Experienced Member | TLV2781 from TI Last edited by speakerguy79; 9th November 2007 at 12:23 AM. |
| New Member | Quote:
the common mode input voltage range for this chip is −0.2 VDD+0.2 So if I am interperating this right, I cannot expect to send the output of my original op amp which swings (possibly) between +12 and -12 volts. given that i will be supplying the tlv2781 with 0 to 2.5 volts on its power supply. Is this right? Dazza | |
| | (permalink) | ||
| Output = Input - Problems | adamthole | Micro Controllers | 20 | 24th April 2007 04:09 AM |
| 555 timer output help for a newbee... | WIZARDSV650S | Electronic Projects Design/Ideas/Reviews | 6 | 6th April 2007 04:04 AM |
| Using PicBasic with Output compare for sounds | mduong77 | Micro Controllers | 7 | 29th March 2007 02:28 AM |
| Output going high on power up?!?! | 2camjohn | Micro Controllers | 5 | 23rd March 2004 06:49 PM |
| How to design such output stage | eeglp | Electronic Projects Design/Ideas/Reviews | 4 | 8th April 2003 06:01 PM |
