Old 9th November 2007, 01:10 AM   (permalink)
Here is a method of controlling the output voltage swing of an op-amp. If the output is too high the top transistor turns on. If the output is too low the bottom transistor turns on.
I am working on an audio amplifier with controlled clipping.
Set the “top clip” and “bottom clip” voltage to correct values.
If the clipped output has less than 5 volts swing do not use the diodes.
If the clipped output is more than 5 volts swing add the diodes.
ronsimpson is offline   Reply With Quote
Old 9th November 2007, 01:17 AM   (permalink)
where do I apply these voltages? to the bases of the transistors?
dazz000
dazza000 is offline   Reply With Quote
Old 9th November 2007, 01:26 AM   (permalink)
I just posted a third picture where the base voltages are set by a resistor divider.
In my case I set the base voltages to +5 and –5.
In your case you want the most positive swing to be 5 volts so set the top base at 4.3 volts.
Old 9th November 2007, 02:13 AM   (permalink)
This is a ridiculously long topic for such a simple problem
speakerguy79 is offline   Reply With Quote
Old 9th November 2007, 02:18 AM   (permalink)
Well I gues your right, I've got plenty of info to go on now so its just a matter of evaluating these ideas. thanks to all who responded. Bye.
dazza000
Old 9th November 2007, 03:34 AM   (permalink)
If anyone ever needs a precision clamp, here's one. The clamping error voltage is only limited by op amp offset voltages, since the diodes are inside feedback loops. It will have a tiny bit of overshoot, dependent on the slew rate of the input signal and the bandwidth of the op amps (assuming they are not slew rate limited). Shown below is a sim using behavioral 10MHz GBW, single-pole op amps, operating on a 1kHz, 20V p-p signal and limiting it to zero and 2.5V. The clip limits can of course be changed.
Sorry, SpeakerGuy.
Ron
Roff is offline   Reply With Quote
Old 9th November 2007, 08:31 AM   (permalink)
Sorry, SpeakerGuy.
Thanks Roff for your considered answer.
dazza000
Output = Input - Problems adamthole Micro Controllers 20 24th April 2007 04:09 AM
555 timer output help for a newbee... WIZARDSV650S Electronic Projects Design/Ideas/Reviews 6 6th April 2007 04:04 AM
Using PicBasic with Output compare for sounds mduong77 Micro Controllers 7 29th March 2007 02:28 AM
Output going high on power up?!?! 2camjohn Micro Controllers 5 23rd March 2004 06:49 PM
How to design such output stage eeglp Electronic Projects Design/Ideas/Reviews 4 8th April 2003 06:01 PM
