| Notices |
A high speed 74HC4046 has a max frequency of about only 8MHz when it has a 5V supply. Their output frequency would need to be multiplied many times to reach 100MHz. A high quality FM stereo Micromitter uses an IC that has a frequency synthesizer with a PLL and it uses a quartz crystal : http://electronics-diy.com/schematic...ransmitter.htm http://electronics-diy.com/BH1417_PL...ransmitter.php
| You can use a low frequency VCO to make FM then multiply its frequency many times to reach the 100MHz FM broadcast band. A PLL is not required. You can use a high frequency VCO and a high frequency counter then use a low frequency phase detector to make your own PLL. You can use a high quality low cost FM stereo transmitter IC that uses a quartz crystal and a PLL frequency synthesizer.
| ...I am also trying to build a simple fm transmitter using the two transistor schematic from: http://www.aaroncake.net/circuits/fmtrans2.gif My question is in regards to the electret microphone here...if I used one of the three wire electret microphones that radio shack sells, how would the diagram change to allow for that third wire? Would I move the placement of the mic down to the junction below so that the white wire is heading towards C4, the ground heading upward and the red wire towards R6? And if this is indeed the case, do I need to add a resistor somewhere? Thanks for taking the time to read this - any advice would be greatly appreciated! -LeeMorgan | |
| That horrible circuit has the antenna connected to its tuned circuit. Then when anything gets close to or moves away from its antenna the frequency changes. It doesn't have a voltage regulator so its frequency also changes as the battery voltage runs down. It doesn't have pre-emphasis (treble frequencies boost) like radio stations have so it will sound muffled on an FM radio because radios have treble frequencies cut (the opposite of the transmitter's boost). 3-wire electret mics have one wire for 0V, one wire for its positive voltage source and the 3rd wire as its output. Look at Electret Microphones in Google and see its datasheet to see if it needs a load resistor to 0V or to the positive voltage source.
http://hem.passagen.se/communication/fm_500.html
__________________ --- The days of the digital watch are numbered. --- | ||
| FM Transmitter noise | the dude of dudes | General Electronics Chat | 1 | 26th April 2007 12:10 AM |
| FM transmitter hack | ArtemisGoldfish | Electronic Projects Design/Ideas/Reviews | 13 | 12th April 2007 10:07 PM |
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 12:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 01:31 PM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 09:55 AM |
