Old 1st November 2007, 04:18 PM   (permalink)
Default IR transmitter IC
sc 7461-103 is a IR remote control transmiter IC. .
it decodes upto 32 addresses (or switches). .
this is wat i find under my TV's remote control.
so thr will b a IC in the TV(reciever) which will decode the signal genrated by the sc7461( transmiter)
can anyone tell wat is the number of the IC in the reciever . .which would be IR remote control reciever IC
mayankguru is offline
Old 1st November 2007, 04:27 PM   (permalink)
There won't be one, the TV will have a micro-controller in it, that will be programmed to decode the IR (as well as all the system control) - the transmitter itself is most probably just a micro-controller as well.
Old 1st November 2007, 06:05 PM   (permalink)
alright . .
can i make 8 different sets of IR remote switch(reciver and transmiter)
i.e there will b 8 recivers and 8 transmitters ,with only one switch on every transmiter.
each reciver can b operated by its transmiter only and not by any other
but without using microcontroller
Old 1st November 2007, 08:31 PM   (permalink)
Originally Posted by mayankguru
alright . .
You 'could', but why would you want to? - if you're not interested in making your own, check the Holtek range of remote control IC's (these, like your remote IC, are simply pre-programmed micro-controllers).
Old 2nd November 2007, 05:06 AM   (permalink)
i need these remote sets in 1000's(quantity)
holtex IC is a bit costly 1.9$
and if i go for holtek then i need 2 holtek IC in each set that will comprise of 3.8$.a bit costly.
as i need just one switch in every tranmitter so is there any cheap solution available.. .
if its not possible to make 8 diffrent set then even 3-4 will or even 2 diffrent set will also work but the solution should b very cheap . . .may be 1$
Old 2nd November 2007, 06:21 AM   (permalink)
Default about ir
hi, do you guys have an idea how to make ir device using pic micro controller?
jay_f1983 is offline
Old 2nd November 2007, 08:36 AM   (permalink)
here it is
http://jap.hu/electronic/codec.html
Old 2nd November 2007, 12:32 PM   (permalink)
Or check my PIC tutorials, but the Holtek chips are only a similar price to PIC's.
FM Transmitter noise the dude of dudes General Electronics Chat 1 26th April 2007 12:10 AM
FM transmitter hack ArtemisGoldfish Electronic Projects Design/Ideas/Reviews 13 12th April 2007 10:07 PM
Attempting to make a Keyfob transmitter... adamthole Electronic Projects Design/Ideas/Reviews 7 25th November 2006 12:05 PM
usb soundcard with fm transmitter Gideonstk Electronic Projects Design/Ideas/Reviews 2 14th June 2006 01:31 PM
Transmitter zachtheterrible General Electronics Chat 3 5th August 2004 09:55 AM
