Notices
Old 1st November 2007, 09:00 PM   (permalink (permalink))
Thumbs up
Nigel Goddwin : Don't you think mobile phones use chips?.
Yes I do.
I'll use a pic and charlieplexing
Ishikawa is offline
Old 1st November 2007, 09:13 PM   (permalink (permalink))
Some one who does a lot of PIC charlieplexing will probably be along shortly!
Old 1st November 2007, 09:27 PM   (permalink (permalink))
I just noticed that with the charlieplexing method will probably be hard to keep each row of leds ON like it is shown in the pictures.
This method will turn them ON and turn them off by the time it turns ON the next row of leds.
Ishikawa is offline
Old 1st November 2007, 09:39 PM   (permalink (permalink))
You do it so fast you can't tell they are flashing, it's a VERY standard technique.
Old 1st November 2007, 10:07 PM   (permalink (permalink))
deleted by original poster.
Ishikawa is offline
Old 1st November 2007, 11:38 PM   (permalink (permalink))
So I need 4 inputs to drive the 8 leds.
From the picture there is 5 wires:
One for the first led always on
One for Ground
The other 3 for the 8 leds (remember the 8 leds r actually considered to be 15)
However from the equation above, 3 inputs drive only 6 leds and there 8 left.
I'm I wrong???
Are you sure that the first LED is always on? I can see it flashing
Use 4 I/O to control 9 LEDs (9 stages), possible? Since the max stages of using 4 I/O is 12.
Superman returns..
bananasiong is offline
Old 2nd November 2007, 12:24 AM   (permalink (permalink))
Originally Posted by ericgibbs
Looking at your 1st posting LED pattern, I would agree with Gordz, a LM3914 set for bar mode. Drive the input of the LM3914 with a ramp voltage.
If your LED's require more current than the LM can supply, use the LM to drive 4/5 transistors, which drive the LED's.
ericgibbs, you seem to be on the right track, a triangle ramp voltage with the
LM3914. Can the triangle wave be clipped on top to allow the full heart to stay on for a shot period of time?
iONic is offline
Old 2nd November 2007, 08:24 AM   (permalink (permalink))
This link has a video that explains charlieplexing very well
http://www.brightcove.tv/title.jsp?t...eup=1028763155
At 5:50 he says: "Only one LED can be ON at any given time" which means I can't turn on more than one led at any given time?...Just wanted to confirm this, I hope I'm wrong.
But then again I saw 3 videos at youtube about charlieplexing and they had more than one led on at a time.
Also at 9:32 he says: "this will give roughly 40mA of peak current going through each led"
then he says: "and therefore the average current through the led is 40mA/20=2mA", so I'm a bit confused isn't there a contradiction??
Please watch the whole video.
Ishikawa is offline
Old 2nd November 2007, 09:09 AM   (permalink (permalink))
I would try using 'two' LM outputs at the 'top' to drive the same LED set.
That would give the appearance of a longer on time.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 2nd November 2007, 11:14 AM   (permalink (permalink))
without using a counter/decoder??
A PIC would be the answer here except the game plan was to use NO counters or decoder
Gordz is offline
Old 2nd November 2007, 11:23 AM   (permalink (permalink))
Use a PIC with enough pins to drive each LED (or pair) and do away with the multiplexing.
This will make the code and the hardware very simple.
Like Erick says Good enough is Perfect.
3v0 is online now
Old 2nd November 2007, 11:25 AM   (permalink (permalink))
I think the OP has dropped that restriction.
The whole point of my project is to do it just like it is shown in the pictures so let's forget about the counter and timers.
3v0 is online now
Old 2nd November 2007, 12:56 PM   (permalink (permalink))
I already answered this above!.
Old 2nd November 2007, 05:44 PM   (permalink (permalink))
bananasiong:
Yep looks like it.
Nigel Goodwin: You do it so fast you can't tell they are flashing, it's a VERY standard technique.
So I have to make the pic to switch between high and low at the 5 inputs fast enough so it won't look like the leds r turning on&off. Is this what u mean?
Ishikawa is offline
Old 2nd November 2007, 08:01 PM   (permalink (permalink))
Yes, check my PIC tutorials for an example of multiplexing LED's.
Parallel L298N Driver circuit help Sidco7 Micro Controllers 1 11th September 2006 10:06 PM
LED Garden Light circuit bryan1 Electronic Projects Design/Ideas/Reviews 5 28th October 2004 12:39 AM
How to make a phone light up internally with LEDs? Batphone! mr.stinkhead Electronic Projects Design/Ideas/Reviews 0 1st April 2004 09:01 PM
light depended circut together with its power supply circuit thabit ahmada Electronic Projects Design/Ideas/Reviews 1 28th March 2004 06:23 PM
neon indicator light in a series circuit whiterabbit General Electronics Chat 9 31st October 2002 09:13 AM
