Hi all
I am trying to make an outdoor robot which avoids obstacle through its sensors. can you guys tell me which sensor would be the best choice. IR may produce unknown results i guess what about you? i have also tested one of the circuit given but this has produced no result plzz help me out ASAP. |
Ultrasonic is more common than IR, and has a greater range than IR.
Your budget and the type of environment are big factors, too. If I had the cash, I wouldn't mind trying out one of these:
http://www.acroname.com/robotics/par...YO-LASER1.html I think the coolest solution, and most likely a less expensive hack than the laser solution above, would be a pair of stereoscopic video camera eyes that compare their images as the robot moves around. Sorry, but that's a little beyond my level of expertise, although I know it's been done. |
Ultrasonic range finder for distance measurement.
http://www.parallax.com/detail.asp?product_id=28015 http://www.parallax.com/dl/docs/prod...-PING-v1.3.pdf There are many different devices like this. It measures distance to 3 meters. Mount one on a rotating head. Measure distance, rotate 10 degrees, measure, rotate etc. You really only need to measure over a 180 or maybe 90 degree angle. The resolution will be low but I think your robot will not walk into trees. Look at the second link. Page 5 shows a +/-7 degree viewing angle on flat objects. It takes 20mS for a measurement. You could see 360 degrees 50 measurements 7 degree resolution in 1 second. |
I like and already know these parallex and other type of modules but the problem is that these are not available in Pakistan.
I have a pair of ultrasonic tx and rx which i tested using 7555 but no results. can you have any good circuitry which is tested, to be made in a short span of time. plzz do let me know. thanking you |
Google for ultrasonic and PIC micro. There is a fair amount of info out there that will get you started, depending on your sense distance you could use a 'feeler' set up connected to micro switches or sprung loaded variable resistors. Low tech but reliable.
I was looking for some tested one. May be cant find on google the tested ones.
thanx anyway bye |
AND |
