I know this is possible I just need some help/advice with it.
I want to power my computer from my 12 volt car battery. I do not want to use an inverter. I do not need to use a monitor just a motherboard (w/CPU,RAM,GFX card), hard drive, and a sound card. The CPU is an old AMD Socket7 1.63GHz. Hard drive is a 80GB Seagate. Anyway I want to know if I can regulate voltages accurately and efficiently enough to keep my system stable with several LM337s and LM317s (negative and positive voltage regulators)? At first I only want it running off a battery ie. no car attached. Can anyone suggest a better regulator for my application? Is there an existing project that solves my problem? Or is it more affordable/easy to invert? Help would be very appreciated. |
--- The days of the digital watch are numbered. --- |
I have been looking around for power inverters and they are fair expensive about $180AUD for a modified sine wave @ 600W. I can't afford this at them moment as I am a student
I am aware that I will have to use several regulators to spread the load across. And I am under impression that the LM337 outputs a negative voltage using a positive input. <<-- correct me if I am wrong. |
If you try to generate +5V from 12V battery with HiGH current demand, you will be wasting lot of power as heat.
once the battery -ve has been used as common for the PC, you will not be able to to use LM337 etc for generating -ve voltages (-5 and -12V) unless the switch mode techniques are used. I presume thatyou only wanted to to avoid going to 12V DC to 230V AC conversion!! Perhaps you areaiming for a DC-DC converter with input 12V battery (13.8 to 10.8 on the lower side) and with normal outputs that are required for a PC mother board and HDD etc. It is possible and there are some manufacturers supplying such DC-DC converters. One such psu is M2-ATX manufactured by www.mini-box.com By such a method you may reduce losses that arise due to double conversion.
Regards, Sarma. Last edited by mvs sarma; 29th October 2007 at 05:15 AM. |
R u trying to make a CAR PC. Awesome
Great website man! They have some really nice stuff.
Regards, Sarma. |
You need -12v and -5v for most PC's so you will have to invert somewhere along the line and the current required for the +5 will be pretty high. The Simple Switcher series from National Semiconductor will be good for this project as they will allow 'simple' inversion as some can be configured as buck/boost/invert.
(permalink) | ||
http://www.mini-box.com/s.nl/sc.8/category.13/.f is the first site on a google search
Its already been done,, it called a 'Laptop'!
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
The negative supply requires less current than the positive supplies to your motherboard etc.. Without using SMP'S, a linear +5V would not be efficient. Also the +12v psu for the PC, from a 12v battery would not be regulated. How much current on each power rail, is the PC going to require? IMO, a SMPS would be the best way to go.
Simple concept Eric, now he should have two chargers for the battery maintenance, I fear.
Regards, Sarma. |
As they say 'there's no such thing as a free lunch' Thats why man invented the SMPS and mains invertor!
| Phone / Computer Headset Mixer | Teflonatron | Electronic Projects Design/Ideas/Reviews | 1 | 19th July 2007 09:59 PM |
| Using a computer power supply WITHOUT a computer? | grrr_arrghh | General Electronics Chat | 13 | 4th April 2007 12:15 AM |
| Alternative computer cooling | Marks256 | Chit-Chat | 23 | 12th March 2007 11:48 PM |
| Inverting and Non inverting Amp Qns | synckewl | General Electronics Chat | 1 | 4th September 2006 10:23 AM |
| Bizzare computer | zachtheterrible | General Electronics Chat | 14 | 31st May 2004 06:07 AM |
