I have just re-read my earlier post regarding '8 special characters', it is a little ambiguous, it could be read as implying that only 8 symbols could be used to represent all the numbers from 0 thru 9, thats not the case. I have kept advising the OP that it would be necessary to create the symbols within the program in real time. Although it isn't a brilliant display, it could be used to show a real time clock. Regards
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Hi there,
Sorry Eric but I think I don't understand what you mean by: Quote:
Problem is that, like Mike already mentioned, the address of the udc is written at the DDRAM addresses not the data of the udc itself. So when I change one udc all DDRAM locations using that udc changes at the same time I think your PIC simulator doesn't react like a real HD44780U does or I'm still missing something I'm using 8051 system en program in assembler. Attached a screen shot of the "Big Font" I planned to make |
I looked
I downloaded Now I will study Thanks a lot... |
Do you understand the Basic language, I know there are many variants, but I will, if you are interested, post my draft copy of the Oshonsoft basic program I have been using for the special characters. The OS LCD sim does respond in this application as per the HD44780. If you examine my program, you will see for each digit, before its written to the LCD, the special character pattern is loaded into DDRAM, it is then called using that special characters address. I write the digit to its designated location on the LCD. eg: consider 6 digits, representing the real time of day, if I want to display the minutes 'tens', the program gets the digit for the time counter, creates the special char pattern for 4 of the LCD pixel blocks, it then writes these 4 spec chars to location number 5 of the LCD. Remember when you do it this way, only 4 LCD pixel blocks, require a new spec char, before its written to the display. When dealing with these LCD's its a good idea to only re-write a digit to the LCD, when that digit has changed from its previous value. There is no point in refreshing the whole display, if only one digit has changed. Let me know what you like to do?
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 30th October 2007 at 07:27 AM. |
(permalink) | |||
When you only write one character that has changed, you need only four user defined characters. It's meaningless to always overwrite the whole LCD. I agree with you for the full 100% But... ... When you change a user defined character all LCD locations that are using those four user defined characters are also changed. Even if you don't explicitly write to those locations, they will change on the LCD. eg. user defined character 1 is used in positions Line1, pos5; Line1, Pos10; Line2, Pos3 and Line2, Pos16 (it's just an example, has nothing to do with your clock or my "big font"). Changing user defined character 1 will result in an immediate change of all four LCD positions mentioned above without any write actions to those locations!!! Apparently the controller is continously updating the LCD display, and that is something your LCD simulator doesn't do (I think)! Quote:
hi mcs,
In that case, using a 2 Row LCD isn't going to get the job done. If you live in the UK, I will send you a 1 * 8 LCD display, with large 11mm high characters, with my compliments, this should give the result you are looking for. I have a number of these LCD's on the shelf, they use the standard HD44780 controller and have an LED back light. If you you are interested, PM your address and I will forward one,, FOC. Regards
Hi Eric, did you get those localy ? They are exactly what I need for a project I am working on for displaying Volts and Amps and a *much* better option than using two 2*16 !
They are from Farnell Leeds or RSComps, about £10's ish. Its a common type, they also come in 1 * 16 I'll see if I can dig out the delivery notes etc.
Or a small VFD display like this Noritake
Hi Eric, Thanks for your offer but I'm not living in the UK. The LCD I'm using has 8mm characters, so I expected a 16mm height font.
Hi Blueroom, Definitely something to look for. Too bad I can't use my LCD library with that one |
To set the record straight, you were correct, reference the LCD Sim, it dosn't obey the 'only 8 special char rule'. Decided to program a PIC, got a repeated character!. We live and learn. Is it possible that you can give your location?
(permalink) | ||
Thnx Eric, I'll look through the Farnell catalogue.
If you need more specification info, let me know.
| User defined characters-alfanumeric LCD | ady689 | Micro Controllers | 13 | 30th October 2007 07:03 AM |
| MP Lab Program Help | bamafan54 | Micro Controllers | 3 | 19th October 2007 02:53 AM |
| User defined Time period 16f628 | jagrolet | Micro Controllers | 4 | 5th September 2006 07:37 PM |
| compiling with MPLAB | evandude | Micro Controllers | 4 | 9th April 2005 08:08 AM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 02:55 AM |
