i want either motion or light to activate a circuit that has a speaker and will sound off a voice, any ideas?
see you can do one thing, make a voltage divider by PHOTO RESISTOR and one common resistor. Give supply to one terminal of photo resistor and connect other terminal to another simple resistor, now take this junction to drive one npn transitor. You shoul put current limit resistor betweent BASE and the junction of npn transitor. Connect buzzer between supply and collector of npn transistor. Ground emitter of same transistor. Here as light falls on photo resistor the voltage at junction of this photo resistor and simple resistor will increase and it will ON the npn transitor. Here the critical thing you have to take care of is selection of voltage divider. This circuit will sound only when the intesity of light is increased. you must put variable resistor in seriese with photo resistor so that you can adjust level of intensity. and so on. there are so many practicles on this you have to do | |
| | #3 | |
Hello I think This is what you are looking for. http://www.talking-alarms.co.uk/index.html Wombweller | ||
| | #4 | |
Which is preferable: motion, or light? If light, should it trigger when it detects more light, or less? How is the voice recorded? (SD Card, tape, .WAV file, what?) What kind of device is it on? What exactly is the application? Burglar alarm? Haunted house FX? What sorts of things have you Googled for so far? It's hard to guess what you're after, so it's hard to guess what to suggest. Torben | ||
its a little speaker , its a 20sec recording module from radio shack, and instead of a button to turn on the speaker i want either light or motion to set it off, it for a pumpkin.
| | #6 |
When somebody steals the pumpkin and rolls it down the street then the recorded voice will say, "Help, I am being stolen!"
| light, motion, sensor |
| security system from a 12 dollar car and and a motion sensor | 2slash | Electronic Projects Design/Ideas/Reviews | 4 | 23rd July 2008 04:47 AM |
| Light sensor with LED's | mcs51mc | Electronic Projects Design/Ideas/Reviews | 13 | 7th July 2006 06:34 AM |
| Light Sensor | behrendfry | General Electronics Chat | 1 | 28th November 2005 05:55 PM |
| Please help light + dark sensor | Hacks | Electronic Projects Design/Ideas/Reviews | 11 | 21st February 2005 02:47 AM |
| motion sensor | mahinda jayasinghe | Electronic Projects Design/Ideas/Reviews | 3 | 11th November 2004 10:19 AM |
