Hopefully the experienced members know that if you connect a motor up to a Audio output, you can hear the music or sound eminate from the Stator. That is exactly what iMotor will do. it will be a ipod or CD speaker sound system using motors for a cool effect. It may seem kind of pointless, seeing how speakers are more efficent, but this is a experiment. THe problem is, is that it is very quiet, and the objective is, is to make it much louder. Try it out for yourself. Should I just connect it up to a audio amp?
The inductance of the motor coil is going to be a problem creating any kind of decent quality audio.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
Yeah, that would be like a 76 ohm speaker. So how would I do it? More volts or what?
Use an equalizer to adjust the frequencies as you like to hear them.
The high inductance of the motor might kill the amplifier. A motor makes a lousy speaker. If you want a speaker then use a speaker.
Uncle $crooge |
I'd think some sort of filter would help. The motor wants DC, but you are feeding it a complex signal. Simplify the signal so the motor isn't fighting itself so much. Guessing the higher frequencies would be heard anyway. Might look into a frequency to voltage converter.
More voltage, usually means more smoke, sometimes flames... |
yeah, it was just a idea
A stepper motor might be a good option. I've seen people using scanner drives to make simple toned music.
how would that work? would I just feed it through one of the coils of the lowest resistance?
Well a typical DC motor wouldn't make a good speaker but a "voice coil" makes a good motor like the kind found in modern hard drives.
http://www.pcguide.com/ref/hdd/op/act_Actuator.htm ![]() |
GOD made all things logically to use them logically.
We waste our time to use certain things which are not made for that purpose. I would like to suggest that you all are very expierienced persons, why you are wasting your time in doing this. Instead you can meke great speakers. not a great motor for sound generation. Please don't mind if i wrote something wrong!! |
Nobody is trying to reproduce Wagner using this setup. It's just an experiment. Anyway, it's not a particularly new idea. I remember when folks were programming C64 floppy drives to play beats and tones. It actually sounded pretty cool but you wouldn't use it to play a CD on. It makes its own instrument. Torben |
There have been many times that I have been told “You can’t do that!” after I had done it.
I enjoy a challenge. Pointless isn’t the point. Especially with electronics, your imagination is the only limitation. You can be very creative, and even if you let the magic smoke out of a few components, it only cost you a few bucks if you didn’t get the parts from your junk pile.
C:\WHUT ? Beware the asterisk * |
I think for them money grows on the tree...Or the have farms of money plant.... I think if this money has been spent for poor countries then that will be better use of money. Can you count money of govenment for these silly practicles? " We do not value of what we have, we know the value of what we dont" |
Hmm... read Mathew 20:1-16 you may find it interesting.
A motor driven speaker diaphragm is a popular concept among the super-loud super-accurate audio crowd. Google(tm) servo contrabass. Mostly used below 125 Hz.
