| Notices |
| | (permalink (permalink)) |
| An audio isolation transformer will isolate the ground on your amplifier from causing bad hum on the telephone line. The cell phone uses air to isolate it from the telephone wires. If you can't simply unsolder 4 pins on a transformer on a modem card then do gardening instead.
| That's a bit harsh audioguru, how would he know what an audio isolation transformer looks like if he's never seen one before? The kind of transformer used in a modem isn't as good as a high quality audio transformer, it'll only pass frequencies between 300Hz and 3kHz instead of 15Hz to 20kHz.
3kHz was down about -12dB. I complained to BELL and they said it was normal. Their limit is -7.5dB one-way which is -15dB round trip. I didn't bother measuring the low frequencies because there weren't any at the receiving end. The response was flat from about 850Hz to about 950Hz. For a few years I installed and programmed (DSP acoustical echo cancellers)high quality boardroom telephone conferencing systems. I made a transmit equalizer that had a peak of +12dB at 3.5kHz. Every time I demo'd my equalizer the people said the sound was much crisper and clearer and it was sold.
| The guy in the store probably had a paging amplifier (5W) attached to his phone system. If you're not concerned about legal ramifications, you can use capacitors to isolate the line. If you don't want shrieks and whistles get a frequency shifter or cut the mic off. | |
| The best thing would be to connect a 1:1 transformer at the points of Reciver (Also called ear piece) at the instrument 4 way cable comming to handset. use the secondary with a resistive divider for matching purposes) At this point the side tone is well suppressed-thus the microphone signals will be minimal.
| I thought he was going to use the headphones output of the phone, not connect to the earpiece. An isolation transformer is needed to avoid hum. A phone makes sidetone so that you can hear how loud or soft you are speaking. Then you will have acoustical feedback howling if the mic can hear the speaker.
| when we try a Mic and a amplifier system ina closed accomodation without proper accoustic arrangements, this howling effect is immennt- unless special care is taken . In case of telephones, i have rarely seen the mute facility when the MIC supply is cut. really very few instruments. I had occassion to couple telephone istrument to a Public address system while inaugurating a LDD/ILD in the telececom deparment ,i was working for. ther i had to do all the rehaursal to ensure smooth and clear broadcast of the speech contesnt of an inaugural call. In this case i can't mute the MICof the telephone. Ofcourse , it went on well.
I hope it works (RadioShack parts have garbage quality) and I hope they say which wire is which.
| COnnecting 2 telephone Sets via optical coupler | waqar | General Electronics Chat | 4 | 20th April 2008 03:07 AM |
| 200 watts Amplifier help | sunny152 | Electronic Projects Design/Ideas/Reviews | 13 | 19th December 2006 09:29 PM |
| linking computer to telephone land line | breconman | General Electronics Chat | 4 | 7th April 2005 09:22 PM |
| Ask for the principle of error amplifier in PWM | swear_swear | Electronic Projects Design/Ideas/Reviews | 2 | 29th July 2003 01:07 AM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 06:21 PM |
