Hello, I'd like your expert advice on how to have a "negative voltage" trigger something. Example will be: a circuit that will be triggered by -5v but not by +5v. I'm looking for a simple and cheap way to achieve this without use of a rectifier or a microprocessor. Is there a simple and cheap logic gate or comparator or anything this newbie is unaware of that will do this? Thank you for your time for this newbie. | |
Use a Schmitt Trigger. If you search this forum for that subject, you will find it in plenty of threads. You could use a voltage compatitor such as the LM311.
__________________ Len | |
Are there schmitt triggers that will handle negative voltage..? Could you please give me a url? Last edited by espresso; 25th October 2007 at 04:00 AM. | |
If the input is always +5V or -5V and nothing inbetween then a diode from the input to output and a resistor from the output to ground will do what you want. With 5V in the output will be 5V out, -5V in will give 0V out. If you want 5V out for -5V in then an inverter after the diode and resistor is needed. Mike. | |
| | #5 | |
__________________ Inside every little problem, is a big problem trying to get out. | ||
| | #6 | |
__________________ Len | ||
| | #7 | |
| | #8 | |
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| | #9 | |
We need more details from Espresso before we can get into specifics. I do see where you are going with this. ie: maybe Espresso wants to interface ECL logic running from a -5V supply. One can only guess at this point. ![]() Espresso: More details please. Tell us exactly what you are trying to do.
__________________ Inside every little problem, is a big problem trying to get out. Last edited by kchriste; 25th October 2007 at 05:37 PM. | ||
| | #10 |
He will need a pot to set the trigger point to exactly -5V because of the component tolerances.
| | #11 |
What exactly are you trying to trigger? A timer? A 555 is normally triggered by a negitive edge, if it must go below 0V then use a diode on the trigger pin to clamp it at -0.6V. What trigger threashold do you need?
| negative voltage, trigger |
| Need help with Schmitt trigger application! | whirlwindz | General Electronics Chat | 8 | 23rd May 2007 01:06 PM |
| Notch filter w/schmitt trigger | whirlwindz | Electronic Projects Design/Ideas/Reviews | 2 | 21st May 2007 03:23 AM |
| Usinging RF Reciever's output to Trigger a 555 one shot | RaG | Electronic Projects Design/Ideas/Reviews | 1 | 2nd January 2005 11:26 PM |
| electronic switch to enable a camera to fire a flashgun | tony ellis | Electronic Projects Design/Ideas/Reviews | 10 | 30th September 2004 11:19 AM |
| power to trigger a 555 monostable? | daviddoria | General Electronics Chat | 4 | 12th June 2004 12:45 PM |
