Old 24th October 2007, 10:53 PM   #1
Default Cascade Regulators or not?
I normally regulate 24vdc down to 5 for projects involving a microcontroller. Now i have one where i have a need for 12vdc also. is there any advantage (heat, effeciency, etc.) to regulating the 12vdc down to 5 instead of going straight from 24 to 5. I use the d2pak type regulators (7805, 7812). Are there any disadvantages (noise, tolerance)? Thanks
jnnewton is offline
Old 25th October 2007, 01:06 AM   #2
Just that the heat generated from burning off the extra voltage is spread over two regulators instead of one. YOu could do 24->12->5, just make sure the 12V regulator isn't overloaded and has the extra capacity to also handle the current drawn by the 5V loads. You could also just use a 24-12 and 24-5. DOesn't realy matter since you need two regulators anyways.
dknguyen is online now
Old 25th October 2007, 01:16 AM   #3
You *really* need to consider using a switchmode device such as the Simple Switcher line from National Semiconductor. I was regulating 5v from 21v which got very warm... with an LM2595T-5.0 I get 5v using the regulator, a schottky diode, an inductor and a cap which stays cool to the touch without a heatsink.
By far the better way to go as cool electronics lasts longer than hot electronics :-)
P.
aussiepoof is offline
Old 25th October 2007, 01:24 AM   #4
24-5 is what, 20% efficiency with a linear regulator? Horrible.
straight answer, har har."
Sceadwian is offline
Old 25th October 2007, 02:41 AM   #5
Doesn't one of the regulators hog all the current until it pops, then it moves onto popping the next one? I had a problem like this with too much heat generation. at 7.2V and 500ma, I was generating 1.8Watts of heat, which is quite a lot for what I generally use. I would definitely use a switching Regulator to prevent all that waste. At 12V and for example 100ma, that is 6 Watts, which is really hot. Use a Active Heat sink to pull the heat off or you should use a switching regulator.
IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
Krumlink is offline
Old 25th October 2007, 02:45 AM   #6
Thanks guys, i will use the switching regulator. thanks guys.
jnnewton is offline
cascade, regulators
cascade 3 4017 counters purcer Electronic Projects Design/Ideas/Reviews 24 15th May 2009 06:09 AM
Voltage Regulators!!! PIG80085 Micro Controllers 4 16th November 2006 01:17 PM
question on voltage regulators ant9985 General Electronics Chat 3 26th September 2005 03:47 PM
Cascade /Cascode. lord loh. General Electronics Chat 1 25th April 2005 06:09 AM
Switching Regulators - How? Dave the Embalmer General Electronics Chat 1 8th March 2003 03:57 AM
