Alright, this is what I think I've found. Correct me if I'm wrong please
Edit-I hope I'm not too far off track, by the end of this post I think there's a solution that might work with an extra resistor. What do you think? I have a knack for popping zeners so I cant test my idea right now LOL As I was going lower on R1 values, the difference on the gauge got smaller and smaller. Reason being, the lower the resistance, the higher the mA at the base of TIP31, but as the mA's get higher, the change of the collector voltage gets smaller as the curve flattens out. To get to the point where I need to be to get the gauge to read full, I've figured the mA input needs to probably be about 10ish mA to get a low enough output voltage at the collector to read the tank full. I hope that doesnt screw up the empty reading too badly, but I'll figure that out as I go. This is how I've sort of gathered the ~10mA figure. Two resistors I've tried- a)3900 b)560 Two zener's I've tried- a)3.6v b)3.9v Results for each- aa)0.923mA ab)1mA ba)6.43mA bb)6.96mA Gathering that with the AB(1mA) combo went to about exactly 3/8'ths tank, and BB(6.96~7mA) was dead on at 3/4, what would I do to find what would give me a full tank considering the collector emitter voltage graph on the datasheet is a curve, so I dont think I can just make a straight line from 3/8 to 3/4 to 1 and change the numbers at the same ratio. If I did though, I would probably need that ~10mA base current to read a full tank on the gauge. If that's right, looks like it's close to something like .16-.18 base/emitter voltage. Couldn't I just use the 3.9v zener, 560 Perhaps there is a better suited transistor all together? Edit 2-The difference between collector emitter voltages between what I have now and what I think would be closer, is so close even a 1 Im just trying to figure out some stuff on my own, right or wrong, but need to get pushed in the right direction again Last edited by Norcal02; 6th November 2007 at 07:09 AM. |
To let you know, I dont expect you to respond to all of this, most of it is just for record keeping and posting just in case any of it is useful.
Update, I found the obvious, putting a resistor between the gauge and collector is just like increasing R2, which only moves the sweep up and down on the gauge, but does not adjust the range larger or smaller. Undecided whether to use 39 To reach the readings above I was using a 3.9v 500mW zener and 220 |
The current required by the base of the transistor depends on the gain of the transistor, and the value or R1 that I suggested was based on typical figures for the TIP31, so it could have been wrong. |
It could well be that a TIP31 has less gain than would be useful. If you put aside everything except the guage, and find out what resistance between the guage and ground makes it read full, and what voltage there is across it at that point, it would help me work out what is happening. Last edited by Diver300; 7th November 2007 at 09:56 PM. |
| Z8 Encore Error index out of range | mootaccount | Micro Controllers | 2 | 17th October 2006 02:23 PM |
| Ultrasonic Range & Penetration | cyprio7 | General Electronics Chat | 16 | 21st May 2006 07:39 AM |
| Ultrasonic Range Finder (SRF08) | elaine84 | Micro Controllers | 3 | 30th August 2005 04:31 AM |
| Massive ERRORS in program. URGENT HELP NEEDED. | davepusey | Micro Controllers | 8 | 18th May 2004 04:13 AM |
| Specifications Applied | Caltech | General Electronics Chat | 1 | 25th December 2003 05:00 PM |
