I want to build the battery tab welder as described here http://www.philpem.me.uk/elec/welder/ I am trying to locate all the parts I need via his schemtaic located here http://www.philpem.me.uk/elec/welder.../schematic.png I need help figuring out the resistor values as far as wattage requirements. Also I am not sure about c1,c2,c3,c4,vr1 I think I have the rest figured out. Tim | |
hi m8 1quater watt ress should be ok there only limmiting current to trani bases you should get components from maplins or get em off ebay. regards
What would c1,c2,c3,c4,VR1 be?
There are all labelled: 100nF 10uF 100nF 100nF 10Kohm | |
I assume 25v capacitors? What exactly is the VR1? I am not sure what the VR stands for. | |
| | #6 | ||
| | #7 |
Thanks..I have pretty much all of the components figured out now. Now the second part I need help with is undertanding all of Vin,grounds etc. I would figure you just need pos/neg but then again I am probably just not smart enough to undertsand this schematic fully. Can anyone give me a dumbed down version of this schematic..maybe a pop-up book =) Seriously, I really would like to build one of these but I dont want to make my hair stand up on end trying to hook it all up. If someone could make up a schematic more easy to follow I would be glad to pay for it. | |
| | #8 | |
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 26th October 2007 at 03:51 PM. | ||
| | #9 |
I got someone off the boards to explain it to me and it makes sense now. What confused me was the multiple power connections and grounds. What I didnt realize is that it was just showing where the 2 circuits tie into eachother.
| | #10 |
I redid the schematic in omnigraffle so it's a little easier to read for those interested. Let me know if there are any mistakes.
| | #11 |
Very cool.. just a few things missing IC2 is 7805 not 1805 IC1 label is missing SCR1 label is missing..and I think it should be drawn so that the lower schematic ties directly into SCR1 and not just in the line as I know SCR1 has 3 prongs. But I could be wrong. I think thats it. | |
| | #12 |
Oh I see now. It's fixed. (I think - is SCR's label correct, I can't read the guy's writing?) I mistook it for a regular diode. Apparently it's silicon controlled rectifier, something I'd never heard of.
| | #13 |
Can 1/6th of a Joule really weld batteries together? These are very impressive spot welds, ![]() Ahhh, just noticed on the link above that the author used a bank of 5 x 120,000uF capacitors. Not 120uF as shown in the diagram above. That ups the energy to 187 Joules. Far more believable. Mike. | |
| | #14 |
Sorry about that, fixed now.
| | #15 |
SCR1 is hard to read its actually 50R1A20. Here is a link to one http://www.irf.com/product-info/data...data/50ria.pdf I have attached my parts list so far. I had to convert my excel file to .txt so its a little hard to read. Last edited by compunerdy; 29th October 2007 at 03:29 PM. | |
| reading, schematic |
| need schematic urgently | ycxxi | Datasheet/Parts Requests | 5 | 3rd December 2007 07:32 PM |
| rms reading | mpj111 | General Electronics Chat | 3 | 10th July 2006 01:37 PM |
| reading a schematic | mike_ss | General Electronics Chat | 6 | 27th December 2005 04:22 AM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 10:23 AM |
| Specifications Applied | Caltech | General Electronics Chat | 1 | 25th December 2003 06:00 PM |
