Hey Peoples...Im quite new to practical PSU design, and would really appreciate help designing :
A variable output power supply -switching - with volt range 0 - 37 v and current range 0 - 3A with polarity consideration. The output of the PSU is meant to automatically change depending on the specs. of the device its connected to. Answers with circuit diagrams would be greatly appreciated. Tnx guys. |
You don't make sense.
A variable output voltage power supply has a regulated output voltage. Its output voltage is not "automatically" changed by its load unless the load needs more current than the current setting of the power supply.
Uncle $crooge |
Lefty
Measurement changes behavior |
This is not just for one specific load, its meant to be useable with different loads of different volatage and current requirements. Do you get where I'm coming from now? |
Think of the load being a 6 volt, 1 amp lamp, the PSU would have no way to automatically know that the lamp has a maximum 6 volt limit and the PSU would just keep raising it's output voltage until the lamp burned out. Do you get where we are coming from?
Which
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
ericgibbs: i mean adjusts automatically.
Thing is lets assume I'm able to let my PSU know the load voltage and current requirments, how do I then adjust its output...maybe via the IC ...as in how do i let my IC ouput voltage change, is there anything like a digital resistor u could program or control in a way...something along those lines... Last edited by maintain; 23rd October 2007 at 02:22 PM. |
There are digital resistors that can be set, usually by a micro-controller, BUT the settings of the digital resistor, for different KNOWN loads would have to preprogrammed into the micro. Tell us what you are trying to do.
Regards, Sarma. |
if load requires more I and cant have it then u get voltage drop ( short circuit) viceversa . do u want a power supply some thing like a switch mode one that gives u what u need ( computer power supply). all bench power supplys just about sense current (I )needs BUT YOU HAVE TO TELL IT BY TURNING THE KNOB . what are u using to psu for ?
What do you mean by polarity consideration?
It sounds like you need more experiance before attempting such a project. I advise you try something like a 1.2V to 15V LM317 supply before building something more complecated.
| Power supply problems - need help and hints | m2elena | General Electronics Chat | 3 | 3rd October 2007 07:56 AM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 12:44 PM |
| Power supply: Fusing to protect circuit | Johnson777717 | Electronic Projects Design/Ideas/Reviews | 4 | 10th April 2004 02:19 AM |
| opinions on variable power supply | johnlouie | General Electronics Chat | 4 | 30th May 2003 11:24 PM |
| power supply timers | JEBB | General Electronics Chat | 10 | 25th January 2003 06:37 PM |
