| Hi, I have a 24V battery and want to connect a 12 Vdc, 20 Amps load (dc motor) to it. How can I regulate the battery's output to the required voltage. Could it be done with the help of some thyristor. Please help in providing some circuit. Thanks, H. S. Bhurji | |
| Use a smaller battery? Usually the motor is the largest load in a system and therefore dictates the battery size. You try to size everything so you DON'T need to regulate the voltage to the largest load, especially for a load that doesn't need regulation (motors being a big example). High current DC-DC converters (that uses MOSFETs or thyristors or whatever) and such costs hundreds of dollars and are not easy to build. WHat's the problem? Can your motor run on 24V but it runs too fast? In that case just use a motor controller (an H-bridge if it's a brushed motor) and run it at 50% PWM. If the motor can't handle 24V, then you cannot do this and should use a lower voltage battery. Last edited by dknguyen; 23rd October 2007 at 05:13 AM. | |
Just make sure to charge both halves equally.
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| Voltage Regulator | Todd | Electronic Projects Design/Ideas/Reviews | 19 | 30th May 2007 11:55 PM |
| convertion of acvoltage to high dcvoltage | panchumarthy | Electronic Projects Design/Ideas/Reviews | 8 | 12th December 2003 02:36 PM |
| Voltage controlled amplifier | Jimbo | Electronic Projects Design/Ideas/Reviews | 2 | 20th October 2003 01:25 PM |
| should i use a voltage regulator on a wall transformer. | macman828 | General Electronics Chat | 3 | 22nd April 2003 08:11 AM |
