| Hello I'm building my own home audio system, and I would appreciate some help. I want to make a peak meter, based on the circuit shown on this page (Thank you jrz126) http://www.electro-tech-online.com/g...3915-help.html But I wanna make a bar for each octave, for example 60, 80, 120, 240, 1K, 3K, 8K, 15K, etc. like the professional analyzers. I think mayble putting a high-pass or lo-pass filter on the entrance of each LM3915 I could do the job. But I don't know what value of condensers / coils to use. Or am I totally wrong? Thank you very much, in advance!!! | |
| You will need individual bandpass filters for each of the frequencies stated. I think Microchip Technologies has a freeware filter designer that would let you figure what you need. A bandpass filter is a combination of high- and low pass filters, by the way. | |
| Here is most of what you need. There are 10 filters and one meter doing the job of 10. The circuit switches the one meter over the 10 filters faster than the eye can see so it looks like there are 10 meters. resolution of 10 x 10. 32Hz, 64Hz, 125Hz, 250Hz, 500Hz, 1kHz, 2kHz, 4kHz, 8kHz & 16kHz. I found this at Eagle CAD Software web sight under downloads—audio. | |
| That is a nice audio real time analyser circuit. It should use an LM3915 that has -3dB logarithmic levels because our hearing's response to loudness is logarithmic. The LM3914 in the circuit is not logarithmic, it is linear with reduced range. Loud music levels will be crammed together and lower levels will be separated too much with an LM3914.
| I'm sorry by the delay, thank you so much ronsimpson! Im looking foward to build the project, but I'm a bit afraid because it seems a little expensive. Last edited by Menticol; 28th October 2007 at 06:19 AM. | |
Thanks BUDY | ||
Anything remotely modern would use a DSP or microcontroller, simplifying the hardware at the expense of complicated software - using FFT (Fast Fourier Transform). | ||
| The circuit designer got a couple of things wrong in his discussion of the circuit:
| Pins 4 and 7 should also be connected to a power supply.
| Menticol, If you build this project…… Audioguru is right, use the LM3915 not the 3914. Audioguru and Hero999 mentioned the power supply pins in the opamps need fixing. You should go to Eagle Cad and download their free software. Make the corrections to the schematic and PCB files. Then have PCBs made. If you need help with the CAD software I could help you. | |
| The main schematic uses quad opamps and their pins are correct. The discussion of the circuits had the pins on the opamps wrong.
| Thank you again, Ronsimpson. I'm trying to put the schematics on the EagleCad, but I'm still too novice with the program and any (very probable) mistake is a money waste. I would prefer to make the changes between the printed circuit and the socket of the IC using wires and some epoxic. I know it is not very professional but I hope it works. Please, What does 2n2 mean in the capacitor's value? Example: 1u = I assume 1 Uf 22n = 22nf But 2n2? I have seen the same thing on resistors value, number, letter (example K) and another number (instead of omega) By the way. do you know about any other mistake on the circuit, Audioguru? In advance, thank you all of you for your help, I will keep posting about the progress of the project and I hope my progress, pictures, conclusions, etc could be useful on any way to all of you Last edited by Menticol; 29th October 2007 at 06:35 PM. | |
| I think the pcb is correct but I didn't look long. The theory discussion is wrong. I am a poet because I rhyme all the time! 2n2 is 2.2nF, 1k5 is 1.5k ohms. They replaced the decimal point with the "n" or "k". I have some 470pF capacitors that are marked n47 (0.47nF). Here is another audio spectrum analyser project. It uses a microcontroller to make the hardware very simple: http://www.electronics-lab.com/blog/?cat=8
| It looks great, but I have no idea about microcontrollers nor this screen Back with the first poject, how many volts does this thing consume? I can see 3 pins for power, but no idea about the other two, and I can't see anything on the pdf | |
| I didn't spend much time trying to see what connects to what. It looks like the LM3915 sinks 12.5mA through the horizontal rows of LEDs. That is not enough current because the multiplexing reduces the duty-cycle and brightness of each LED to only 10% which is only 1.25mA. Very dim. The project is confusing because it uses many connectors but the details about them are written in Vietnamese. The current-limiting for the LEDs is done inside the LM3915. So when a 12V supply is used and all LEDs are turned on then the outputs of the LM3915 are 8.5V (3.5v blue LEDs) with 12.5mA. Then all ten outputs dissipate 1.1W. If the LEDs are 1.8V red ones then the LM3915 dissipates 1.3W. Its absolute max allowed dissipation is 1.365W. If a 9V supply is used then the dissipation in the LM3915 with blue LEDs is 0.69W and with red LEDs is 0.9W which is better. The opamps and Cmos logic ICs work fine with a 9V supply so I would power the project with regulated positive and negative 9V supplies.
| Analog Meter | windozeuser | General Electronics Chat | 19 | 3rd October 2007 03:44 PM |
| Simple Field Strength Meter | ElectroMaster | Electronic Projects | 8 | 14th June 2007 02:07 PM |
| peak program meter question | Othello | General Electronics Chat | 9 | 30th November 2006 01:30 AM |
| Meter Data Sheets | Overclocked | Datasheet/Parts Requests | 4 | 12th June 2006 11:26 PM |
| Panel meter, analog VS digital | Johnson777717 | General Electronics Chat | 7 | 23rd June 2004 12:33 AM |
