Hiya Guy's,
Last night on the box a bloke was showing an electric fence checker that showed if the wire was live by just placing a unit close to the wire not touching it and the unit just sounded a beeper. He mentioned it picked up the static (electro magnetic interference) of the fence. Anyone got any idea's how this would work as I'd be keen to learn more about it. Cheers Bryan
" The only way to avoid human error is to avoid the use of humans" |
I would try a small portable radio, tuned OFF a channel, hold it close to the wire, [not too close] if its a pulsing fence you should hear a click, click.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Here is my best guess, see the attached sketch.
In the fence wire is a high voltage pulse, by holding the tester close to the wire there will be some capacitive coupling into the circuit in the box. There will also be a resistive path the ground through our little stick man*. At the junction of the capacitor and resistor there will be nice spiky pulses which can be used to trigger a beepy thingy. So informing our man "dont touch this you great galah" * a guy called LS Lowry became famous for this paintings of stick figures, which now command high prices. How much for my magnum opus? JimB (in frivolous mood)
Experience is directly proportional to the value of the equipment ruined. |
hi Jim,
Regards
I need to find electric wires under ground. (60hz 220v)
I built two different “boxes”. The first one worked much like JimB suggests where the antenna is a copper plate that capacitive couples to the power line. The second box picks up the magnetic flux lines from current in the wires. They both work. I think detecting electricity in a fence is much easer. Higher frequency components, higher voltage, much closer to detector,…… Close to the barn there is serious current on the fence and much high frequency signals. A mile away the current is not detectable and much of the high frequency is gone. When I was young there was a very good way to tell if the fence was hot. “Ha Bryan, come and touch the fence!” |
This message transmitted on 100% recycled electrons
I use to test our fence by touching it. I would have thick soled trainers (sneakers) on and the effect was just a tingle. One day I was out in the rain in bare feet, ended up in a load of mud and ended up touching the fence. Boy, did that hurt. I am now very wary of the fence when I have no shoes on. For the curious, it's quiet normal here to walk around shoeless.
FYI, here's a link to the device in question. Mike. |
How about a pen style voltage detector?
http://www.flukenetworks.com/fnet/en...ategorycode=HT That's Fluke's website they probably cost a fortune. You can find them cheaper by shoppnig around I'm sure.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
I use one straw of green grass.
Hold it at the end and slowly slide it closer over the live fence wire. You will feel a small tingle at some stage, depends also upon how wet the grass is. The distance on the grass from when you feel the tingle will give you an approx idea that the wire is live.
There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. |
Just throw a young kid on it, see how far he jumps!
What's wrong with kids today, we used to always be playing with electric fences as kids!. |
I used to test fences by just grabbing the wire as well. I never got anything more than a tingle, but then again, i was always wearing shoes.
There is no "I" in "team", unless Apple makes it... Then it would be iTeam. |
I was feeding horses at a friends farm one day, it was raining and the ground was soaked and muddy.
I had a heavy bucket of grain in each hand and stepped right near a wooden fence that had an electric wire on it. My foot sank deep into a mud hole and I leaned against the wire, and could not get off of it. I had touched electric fences many times, but ths was different, the pulsing shocks were much stronger than normal, my heart started skipping beats. As I tried to get off the wire I thought about all the animals ( deer , rabbits turkey and snakes I had seen dead on and tangled in electric fence wires, and I thought, oh! thats how they all died! After maybe 10 seconds,- I finally got off that damn wire and my heart was still skipping and I felt very weak and sick to my stomach. I felt like crap for a couple of days after. I was only 29 and in good health when this happend. sam |
Well, you are still alive, so maybe you won't be joining that snake for a while more, huh?
I always tested our electric fence for the dogs with the above mentioned blade of grass technique.
The old style testers used a neon light with a current limiting resistor, and a nail you pushed into the ground
| Electric Fence Voltage | antksmit | General Electronics Chat | 5 | 17th January 2007 09:49 AM |
| Electric fence | zachtheterrible | General Electronics Chat | 6 | 15th June 2005 04:33 PM |
| Electric fence doesn't work? | teslatower | General Electronics Chat | 46 | 3rd June 2005 05:31 PM |
| Electric fence tester. | KOEZE | Electronic Projects Design/Ideas/Reviews | 10 | 30th September 2003 07:04 AM |
| electric fence | j day | Electronic Projects Design/Ideas/Reviews | 1 | 14th September 2003 04:59 PM |
