Hi, I've been given a task to build a receiver to detect some low-power transmitter. The following are the given details about the transmitters:
Here are my questions... I'm confused about the frequency it will operate in and the frequency for it's output, is the frequency in the output a hint for decoding the Morse code? Is there some special name for the antenna, filters, amplifiers, etc. used for building a receiver of this type? As when I googled "receiver antenna", I sort of get some random information, and I'm not sure if it's relevant to what I'm looking for.... Could someone please point me in the right direction as a start for this task? Thanks in advance |
try "fox hunt receiver"...
Thx ^^, this shld help me get started nicely
Yagi's (antenna) are often used because they're highly directional.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
I dont think so, at least not for this application! JimB
Experience is directly proportional to the value of the equipment ruined. |
Must the Morse code be identified through sound?
Because I came through some other transmitter hunting competition and they all used sound to identify the Morse code... Another question: What is the relation between the 80m and 3.5MHz, what does 80m actually means? Last edited by forever99482; 17th October 2007 at 12:04 AM. |
No your right Jim. S'what I get for quick responces =)
I did a little more googling, and found this link. http://members.aol.com/joemoell/80intro.html
(300000 km/s) = (3.5 MHz) times (80 m) 80 meters is the wavelength sam Last edited by sam2; 17th October 2007 at 06:03 AM. |
Thank You
80 meters is an international amateur radio band and "fox hunting" is one of many amateur radio activities.
A loop antenna might prove to be useful as they tend to be quite directional. There are two parts to directional here - orientation of the antenna for maximum signal and orientation for minimum or null. My experience is that the null is quite sharp. The loop can be a ferrite loop or simply a loop of wire or coax. Tuned loops perform well. A tuned loop for the AM broadcast band in the US might be 24 inches square with about 20 turns of wire and a variable capacitor to resonate the loop. For higher frequencies you might short some of the turns.
stevez Last edited by stevez; 17th October 2007 at 10:52 AM. |
Here's a site all about this. It is called Radio Direction Finding (or Fox Hunting).
http://members.aol.com/homingin/ There seems to be a lot of information about this activity on this site, including links to reciever projects. Here's another google hit with project info: http://home.att.net/~jleggio/projects/rdf/rdf.htm A receiver for 80 meter hunting is probably just a conventional analog AM (voice) shortwave receiver with an added beat frequency oscillator to allow you to hear morse code. The morse code comes out of a speaker as simple beeping sounds, with an on-off pattern. So, for your receiver project, you should probably try to find a very simple receiver schematic for a basic SSB/CW receiver for 80 meters. There are many of such things on amateur radio sites and in fact the simplest designs are often those specifically for what the hams call QRP operation. QRP simply means low power operation and is the kind of equipment that hikers take along on their travels. Obviously you are new to receiver design and construction, so I would recommend this: if your task is to build a receiver, then buy a kit. If your task is to design a receiver as a learning exercise, then start with a receiver IC data sheet, say for example with the http://www.shfmicro.com/TEA5551T.pdf There are many other receiver chips out there that can form the basis for a one-chip radio for your purposes. I don't have a kit to recommend, but perhaps you can find one with google or the above enthusiast sites.
RadioRon Last edited by RadioRon; 17th October 2007 at 05:21 PM. |
Using an IC seems very over complicated?, an 80m CW receiver is a VERY simple and easy device, try googling for "direct conversion receiver". They are easy to build, simple, yet work incredibly well.
Thanks, will look up on it now
Actually, I was wondering if it is possible to build an antenna which the shape look like the antenna of the old type mobile phone (those that you'd need to pull out the antenna type)? because the loop type antenna is sort of bulky and not really user friendly. (In terms of having to point in the right direction to get a maximum signal) Actually, this is my 3rd year project, trying to beat other teams XD Last edited by forever99482; 18th October 2007 at 05:02 PM. |
It seems there are at least two ways to look at this.
Both suggest a receiver that will indicate signal strength - or at least it is helpful to have the meter. In one approach you attach a directional antenna and plot lines on a map that might suggest direction. You change locations somewhat and plot more lines - the thought being that where the lines converge is the source. This is probably best where distances are greater. In another approach you have a receiver and non-directional antenna. You move from place to place checking field strength. You might plot info on a map to help point the way. This approach might be most useful for low power stuff that's relatively close. I mention this because you ask about a telescoping antenna - which won't have much directional capability. It may be that for your use a directional antenna might not be of much help. A metered receiver and possibly an attenuator on the antenna input might be helpful. The attenuator would serve to reduce the signal to the receiver as you got really close in.
stevez |
Another question just came to mind when you mentioned plotting lines on a map to find the transmitters. As usually these type of competition would be in an open field with trees, but in my case, it is an open field with buildings.
Is there a possibility that the radio waves might get reflected by the buildings(mostly bricks and windows)? |
| Radio Control Demystification Anyone? | Peter_wadley | Electronic Projects Design/Ideas/Reviews | 19 | 30th April 2007 11:53 PM |
| AM Radio troubles when testing | CParsec | General Electronics Chat | 2 | 18th January 2005 01:33 AM |
| Radio shack transistors | zachtheterrible | General Electronics Chat | 10 | 24th August 2004 11:26 AM |
| Old Radio Shack P-Box Schematics | brokepoker | Electronic Projects Design/Ideas/Reviews | 1 | 23rd July 2004 05:07 PM |
| my FM radio has frequency problems. | mstechca | Electronic Projects Design/Ideas/Reviews | 3 | 21st April 2003 11:01 AM |
