Old 15th October 2007, 04:21 PM   #1
Default Can a 74LS153N be used for a BEAM Bot?
I have a handle full of LS32 and LS153 chips that I would like to use in building BEAM Bots with a group of boys I'm working with in the Royal Rangers. Any and all suggestion for circuit design would be very appreciated.
donduvall is offline
Old 15th October 2007, 06:23 PM   #2
http://www.solarbotics.net/bftgu/starting_elect_ic.html
This site is all BEAM stuff (likely already know). They say the LS consume a lot of power compared to more modern versions. Guess you could use any series, just need to be prepared to feed it...
HarveyH42 is offline
Old 16th October 2007, 06:00 AM   #3
If you can pull out a very regulated 5 volts to feed them then I wouldnt see why not...
If it is for a LED, it isnt going to be very satisfactory, because it wont be very bright. I would add a transistor to the output to get some more milliamps to it.
IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
Krumlink is offline
74ls153n, beam, bot
Hard Wired Garage Door Opener via High Beam with Timeout MOOREJT1 Electronic Projects Design/Ideas/Reviews 12 11th February 2008 06:33 AM
IR Beam Motor Control rustyh General Electronics Chat 2 18th October 2006 07:21 PM
Dual Beam People Counter Problem........ fingers Electronic Projects Design/Ideas/Reviews 7 21st September 2004 01:02 PM
Motor control VIA Logic and IR LED Beam Johnson777717 Electronic Projects Design/Ideas/Reviews 4 16th March 2004 06:21 PM
