Hi Guys Firstly, if this isn't the place to post this question please advise. OK I need to be able to move an object about 1 kg in weight, up and down over 2 - 4 inches at an adjustable speed. I have been told that a stepper motor & PIC16F84A will be able to do the job. The unit will need to be programmed and standalone (hence the PIC) and plugged into a UK wall socket via a power supply, have 3 push buttons to set 2inch/3inch/4inch strokes with a speed adjuster from approx 50 strokes per minute (slowest) to 100 strokes per minute (max) the duration could be anywhere from 10 minutes to an hour. The motor (just for your info) will have a crank arm on it approximatly 2 inches in length, the motion should be as smooth as possible in the transition between back and forth. I need to know A) If it's at all possible, if not, then suggestions/advice on how to accomplish it B) Is there something already available that would accomplish this C) Someone in the UK (preferably North West,ish) able to design the above item I do not intend to build it myself as I have no idea, just looking for someone with enough knowledge to design it and supply the finished working item, I am located in Cumbria. Thanks for reading my post | |
For a start don't use the 16F84 (unless you have an old box full of them), it was replaced last century by the cheaper, faster, higher spec 16F628 - and you wouldn't need a crystal with that either. As for your project, you need to check the mechanical side first, ensure a stepper motor has the power you require - a servo motor might be more suited?, or even just a DC motor and H-Bridge?. | |
Thanks for your reply Nigel As I stated in my initial post, I have no idea how to get to what I need, I take your point on the mechanical side and am totally open to suggestions. Do you know of anything that would do what I want? could it be built? | |
Yes it could be built, perhaps you could post a drawing of the sort of thing you're anticipating?. I find it difficult to imagine, and from what you've said it sounds like a hoist or crane would do the job?.
What you are describing can be designed and built. As suggested, you need to work out the mechanics of it first. The lift of the 1 kg weight over 4 inches at 100 strokes per minute will likely define the absolute minimum power required of the motor - then you need to add for the inefficiency of your system (probably determined experimentally). The motor must be able to deliver the power/torque required at all speeds within your design range. One engineering term used to define the smoothness between "back and forth" is jerk - the change in acceleration. The mechanical system and the behavior of your motor will determine this. With careful programming you might be able to overcome some limitations of your mechanism. While this isn't a huge project it's certainly going to take some work.
__________________ stevez | |
| | #6 |
Thanks Nigel & stevez OK, before I made this thread, I had already been given a driver board kit and programmer kit, they came with the PIC16F84A, a friend got them from Magenta here in the UK. I have never built anything before like circuit boards but after your comments decided to atleast try so I can see for myself how it all works, then maybe stop asking dumb questions here, they both went together and seem to work correctly, its taken 2 days. I have downloaded ic-prog and installed it on XP Pro, it works WITHOUT the errors (yes I got them and had to install the dll). I have since been able to read and write to the chip with the sample files Magenta provided, then stumbled after realising I needed to import .HEX files only, then came MPLAB, more learning, OK to date (in 2 days) I have built a board that runs the motor and a board to programme the chip. I cannot work out 'where' to change the .asm file to change speed, direction, etc, I also can't understand what NEEDS to be in the file and what doesnt. Their example does what appears to be 3 things, when powered, rotates the motor in steps for 3 full revs then reverses the same process but a touch quicker, then gives about 25 full revs at a faster speed, the driver board has a reset on it and when pushed it starts the whole sequence over. I have searched the web for .asm example files, tried some and the motor does nothing, I can't tell if they are supposed to be used with my chip or not. Does anyone have a simple .asm for this chip that will simply rotate the motor left then right 180deg in a loop? or a sample of code that would do just that, it would be much appreciated if the file had understandable comments too. ps, Nigel, you must be famous as every file I have seen has your name on it, if it is you please accept my bows | |
| | #7 | ||
IC-Prog even incorporated an early version of my dis-assembler, but never asked permission, or even notified me he had done so - but he did leave my copyright notice in place!. | |||
| | #8 |
Heres the example asm file I have Code: PROCESSOR 16F84A
TITLE "STP12.ASM - PIC 16F84A STEPPING MOTOR DRIVER"
RADIX HEX
LIST
#DEFINE INDF 0000 ;PAGE 0 & 1 INDIRECT ADDRESS
#DEFINE RTCC 0001 ;PAGE 0
#DEFINE OPTN 0001 ;PAGE 1 (0081)
#DEFINE PCL 0002 ;PAGE 0 & 1 PC LOW BYTE
#DEFINE STATUS 0003 ;PAGE 0 & 1
#DEFINE FSR 0004 ;PAGE 0 & 1
#DEFINE PORTA 0005 ;PAGE 0
#DEFINE TRISA 0005 ;PAGE 1 (0085)
#DEFINE PORTB 0006 ;PAGE 0
#DEFINE TRISB 0006 ;PAGE 1 (0086)
#DEFINE EEDATA 0008 ;PAGE 0
#DEFINE EECON1 0008 ;PAGE 1 (0088)
#DEFINE EEADR 0009 ;PAGE 0
#DEFINE EECON2 0009 ;PAGE 1 (0089)
#DEFINE PCLATH 000A ;PAGE 0 & 1
#DEFINE INTCON 000B ;PAGE 0 & 1
#DEFINE DELAY0 000C ;PAGE 0 DELAY LOOP COUNTER
#DEFINE DELAY1 000D ;PAGE 0 DELAY LOOP COUNTER
#DEFINE DELAY2 000E ;PAGE 0 DELAY LOOP COUNTER
#DEFINE UPBYT 000F ;PAGE 0 STEP PAGE ADDRESS
#DEFINE INDEX 0010 ;PAGE 0 STEP NUMBER
#DEFINE FLAGS1 0011 ;PAGE 0 SYSTEM FLAGS 1
#DEFINE SPEED 0012 ;PAGE 0 SPEED VALUE STORE
#DEFINE SPEED1 0013 ;PAGE 0 SPEED1
#DEFINE SPEED2 0014 ;PAGE 0 SPEED2
#DEFINE STPSL 0015 ;PAGE 0 LSD OF STEP COUNTER
#DEFINE STPSM 0016 ;PAGE 0 USD OF STEP COUNTER
; STATUS REGISTER BITS
#DEFINE CARRY 0X03,0 ;CARRY FLAG
#DEFINE DCARRY 0X03,1 ;DECIMAL CARRY FLAG
#DEFINE ZERO 0X03,2 ;ZERO FLAG
#DEFINE RPAGE 0X03,5 ;REGISTER PAGE SELECT
; OPTION REGISTER BITS
#DEFINE PS0 0X01,0 ;P1 - PRESCALER SELECT VALUES
#DEFINE PS1 0X01,1 ; ''
#DEFINE PS2 0X01,2 ; ''
#DEFINE PSA 0X01,3 ;P1 - PRESCALER ASSIGNMENT
#DEFINE RTE 0X01,4 ;P1 - TMR0 EDGE (WHEN EXTERNL)
#DEFINE RTS 0X01,5 ;P1 - TMR0 SOURCE
#DEFINE INTEDG 0X01,6 ;P1 - B0 INTERRUPT EDGE
#DEFINE RBPU 0X01,7 ;P1 - PORTB WEAK PULL UPS
; INTCON REGISTER BITS
#DEFINE RBIF 0X0B,0 ;PORTB CHANGE FLAG
#DEFINE INTF 0X0B,1 ;B0 INT FLAG
#DEFINE T01F 0X0B,2 ;TIMER 1 INTERRUPT FLAG
#DEFINE RBIE 0X0B,3 ;PORTB CHANGE INTERRUPT ENABLE
#DEFINE INTE 0X0B,4 ;B0 INTERRUPT ENABLE
#DEFINE T01E 0X0B,5 ;TIMER 1 INTERRUPT ENABLE
#DEFINE EEIE 0X0B,6 ;EEPROM WRITE INT
#DEFINE GIE 0X0B,7 ;GLOBAL INTERRUPT ENABLE
; PORTA BITS
#DEFINE SWA1 0X05,0 ;P0 - A SWITCH INPUT 1
#DEFINE SWA2 0X05,1 ;P0 - 2
#DEFINE SWA3 0X05,2 ;P0 - 3
#DEFINE SWA4 0X05,3 ;P0 - 4
#DEFINE SWA5 0X05,4 ;P0 - 5
; PORTB BITS
#DEFINE PHASE3 0X06,0 ;P0 - MOTOR DRIVE PHASES 3
#DEFINE PHASE4 0X06,1 ;P0 - 4
#DEFINE PHASE2 0X06,2 ;P0 - 2
#DEFINE PHASE1 0X06,3 ;P0 - 1
#DEFINE SWB1 0X06,4 ;P0 - B SWITCH INPUT 1
#DEFINE SWB2 0X06,5 ;P0 - 2
; #DEFINE 0X06,6 ;P0 - PROGRAMMING INPUTS
; #DEFINE 0X06,7 ;P0 - PROGRAMMING INPUTS
; FLAGS1 BITS
#DEFINE FWDFLG 0X11,0 ;P0 - FORWARD RUN FLAG
#DEFINE RUNFLG 0X11,1 ;P0 - RUN FLAG
#DEFINE STEPF 0X11,2 ;P0 - FULL STEP FLAG
#DEFINE STEPC 0X11,3 ;P0 - STEPS DONE FLAG
ORG 0x000 ;RESET VECTOR
GOTO FIRST ;
ORG 0X004 ;INTERRUPT VECTOR
GOTO SERVE1 ;INTERRUPT SERVICE ROUTINE
FIRST ORG 0x005 ;FIRST INSTRUCTION
NOP
NOP
NOP
GOTO START ;
ORG 0X10
START BCF RPAGE ;MAKE SURE PAGE 0
CLRWDT ;CLEAR WATCHDOG TIMER
;* CLEAR REGISTERS *
;CLEAR OPERATING REGISTERS LOWER BANK
MOVLW 0X0C ;LOAD FIRST REGISTER ADDRESS
MOVWF FSR ;TO FILE SELECT REGISTER
NXREG CLRF INDF ;CLEAR SELECTED REGISTER
INCF FSR,1 ;INCREMENT POINTER
MOVLW 0X30 ;LOAD TOP LOCATION +1 TO W
SUBWF FSR, 0 ;SUBTRACT FROM CURRENT ONE
BTFSS ZERO ;CHECK TO SEE IF EQUAL
GOTO NXREG ;IF NOT - LOOP
;SET UP INITIAL PORT DATA
MOVLW B'00010000' ;MOVE DATA FOR PORTA
;Note that A4 MUST be high if
;it is to be used as an input
;otherwise open collector will
;pull it down.
MOVWF PORTA ;LOAD TO PORTA REGISTER
MOVLW B'00000000' ;MOVE DATA FOR PORTB
MOVWF PORTB ;LOAD TO PORTB REGISTER
; PAGE 1
;SET UP PORT I/O AND OPTION REGISTER CONTENTS
BSF RPAGE ;SET PAGE 1
MOVLW B'00011100' ;SET A0&1 TO OUTPUT,
MOVWF TRISA ;LOAD TO I/O CONTROL REG A
MOVLW B'11110000' ;SET B0-3 TO OUTPUT
MOVWF TRISB ;LOAD TO I/O CONTROL REG B
NOP
NOP
BCF RBPU ;ENABLE PORTB PULL UPS
BSF INTEDG ;SET B0 INT ON RISING EDGE
BCF RTS ;TIMER COUNTS INT CLOCK
BCF RTE ;LOW-HIGH INT EDGE (UNUSED)
BCF PSA ;ASSIGN PRESCALER TO TIMER
BSF PS0 ;SET UP PRESCALER TO /256
BSF PS1 ; ''
BSF PS2 ; ''
BCF RPAGE ;BACK TO PAGE 0
; PAGE 1
CLRF INTCON ;CLEAR ALL INTERRUPTS & FLAGS
MOVLW 0X02 ;LOAD DATA STRING POINTER
MOVWF UPBYT ;FOR UPPER ADDRESS BYTE
CLRF INDEX ;ZERO LOWER ADDRESS POINTER
;PROGRAM OPTION 1) SQRUN RUNS DEMO AND THEN READS DIRECT DRIVE SWITCHES ;select required option
BTFSC SWB1 ;TEST PORT B4
GOTO SQRUN ;B4 IS HIGH OR OPEN - DO DEMO RUN FIRST
GOTO DDRIVE ;B4 IS LOW - LINKED TO 0V
;PROGRAM OPTION 2) DDRIVE SKIPS DEMO RUN AND READS DIRECT DRIVE SWITCHES IMMEDIATELY. ;
;DDRIVE - OPTION 1 DIRECT DRIVE
;select full or half step mode
DDRIVE BCF STEPF ;SET FOR FULL STEP,
;CLEAR FOR HALF STEP
; ;select speed counter value
MOVLW 0X80 ;LOAD VALUE FOR SPEED COUNTER
MOVWF SPEED ;INTO SPEED REGISTER
MOVWF RTCC ;AND INITIALISE RTCC REGISTER
BSF T01E ;TURN ON TIMER INTERRUPT
BSF GIE ;AND ENABLE GLOBAL INTERRUPTS
;Run loop - tests push switches and runs forward or reverse in response
RUNING BTFSS SWA4
GOTO FRUN
GOTO ADRUN
FRUN MOVLW 0XF4 ;LOAD VALUE FOR SPEED COUNTER
GOTO ADRUN
ADRUN BTFSS SWA3 ;TEST 'FORWARD' SWITCH
GOTO FWDRUN
BTFSS SWA5 ;TEST 'REVERSE' SWITCH
GOTO REVRUN
BCF RUNFLG ;CLEAR RUN FLAG 'STOP'
GOTO RUNING ;LOOP FOREVER
FWDRUN BSF FWDFLG ;SET DIRECTION
BSF RUNFLG ;SET TO RUN
REVRUN BCF FWDFLG
; SERVE1 INTERRUPT SERVICE ROUTINE
SERVE1 MOVF SPEED,0 ;RELOAD SPEED COUNTER VALUE
MOVWF RTCC ;INTO TIMER COUNT UP REGISTER
BTFSS RUNFLG ;TEST RUN FLAG
GOTO ENDSTP ;IF NOT SET, EXIT
BTFSC STEPF ;TEST FLAG FOR FULL STEP
CALL DRIVE ;FULL STEP CALL 'DRIVE'TWICE
;TO JUMP OVER HALF STEPS
CALL DRIVE ;WORK OUT FOLLOWING STEP
CALL STEP ;EXECUTE STEP
CALL STPCNT ;DECREMENT POSITION COUNTERS
ENDSTP BCF T01F ;CLEAR INTERRUPT FLAG
RETFIE ;RETURN FROM INTERRUPT
; DRIVE CALCULATES STEP NUMBER & LOADS INTO INDEX
DRIVE BTFSS FWDFLG ;TEST DIRECTION FLAG
GOTO REVSE ;IF CLEAR REVERSE
; ;FORWARD
INCF INDEX,1 ;INCREMENT STEP COUNTER
BTFSC INDEX,3 ;8 HALF STEPS?
CLRF INDEX ;IF 8 RESET TO ZERO
RETURN
; ;REVERSE
REVSE MOVF INDEX,1 ;TEST VALUE OF STEP COUNTER
BTFSC ZERO ;
BSF INDEX,3 ;IF ZERO RELOAD
DECF INDEX,1 ;AND DECREMENT
RETURN
;SQRUN OPTION2 MOTOR SEQUENCE DRIVE
SQRUN
; ;first run:
MOVLW 0X02 ;SET NUMBER OF STEPS
MOVWF STPSM ;MSD
MOVLW 0XA0 ;
MOVWF STPSL ;LSD
CALL RUNSTP
; ;second run:
MOVWF STPSM ;MSD
MOVLW 0XA0 ;
MOVWF STPSL ;LSD
BCF FWDFLG ;SET DIRECTION
MOVLW 0XA0 ;LOAD VALUE FOR SPEED COUNTER
CALL RUNSTP
; ;third run:
; ;same speed so leave previous
; ;values
MOVWF STPSM ;MSD
MOVLW 0XA0 ;
MOVWF STPSL ;LSD
CALL RUNSTP ;
; ;forth run:
MOVLW 0X10 ;SET NUMBER OF STEPS
MOVWF STPSM ;MSD
MOVLW 0XA0 ;
MOVWF STPSL ;LSD
CALL RUNSTP ;
BCF RUNFLG ;CLEAR FLAG
CALL PAUSE2
CLRF PORTB
LAST GOTO DDRIVE ;LAST MOVE COMPLETED
RUNSTP BCF STEPC ;CLEAR FLAG
MOVF SPEED,0 ;LOAD SPEED REGISTER INTO W
RUNIN BTFSS STEPC ;LOOP WAITING FOR INTERRUPTS
GOTO RUNIN ;UNTIL FLAG IS SET
BCF GIE ;THEN DISABLE INTERRUPTS
RETURN ;AND RETURN
;STPCNT - STEP COUNTING ROUTINE
STPCNT MOVF STPSM,1 ;IS MSD ZERO
BTFSC ZERO ;TEST ZERO FLAG IF ZERO - JUMP
GOTO JUSTL ;ZERO FLAG SET, SO JUMP
;MSD IS NOT ZERO
MOVF STPSL,1 ;IS LSD ZERO
BTFSC ZERO ;
DECF STPSM,1 ;LSD IS ZERO SO DEC MSD
DECF STPSL,1 ;DEC LSD (ROLLS OVER TO FF)
RETURN ;AND RETURN
;MSD IS ZERO
JUSTL DECFSZ STPSL,1 ;DECREMENT LSD
RETURN ;
BSF STEPC ;IF ZERO ALL DONE - SET FLAG
RETURN
;PAUSE2 GIVES LONG DELAY BY LOOPING 10 TIMES CALLING PAUSE1 EACH TIME
PAUSE2 MOVLW 0x40 ;MOVE SET UP PAUSE DELAY
MOVWF DELAY2 ;TO DELAY2 REGISTER
DEL2LP CALL PAUSE1 ;CALL SECOND LOOP
DECFSZ DELAY2, 1 ;DECREMENT SAMPLE PULSE COUNT
GOTO DEL2LP ;AND LOOP UNTIL IT IS ZERO
RETURN
;PAUSE1 GIVES MEDIUM DELAY BY LOOPING 10 TIMES CALLING PAUSE EACH TIME
PAUSE1 MOVLW 0x80 ;MOVE SET UP PAUSE DELAY
MOVWF DELAY1 ;TO DELAY1 REGISTER
DEL1LP CALL PAUSE ;CALL SECOND LOOP
DECFSZ DELAY1, 1 ;DECREMENT SAMPLE PULSE COUNT
GOTO DEL1LP ;AND LOOP UNTIL IT IS ZERO
RETURN
;PAUSE GIVES SHORT DELAY BY LOOPING FF TIMES
PAUSE MOVLW 0x08 ;MOVE SET UP PAUSE DELAY
MOVWF DELAY0 ;TO DELAY0 REGISTER
DELLP DECFSZ DELAY0, 1 ;DECREMENT SAMPLE PULSE COUNT
GOTO DELLP ;AND LOOP UNTIL IT IS ZERO
RETURN
;* MOTOR DRIVE BLOCK *
;This routine takes the start addresses from UPBYTE and INDEX and collects
;the motor drive pattern from ROM.
ORG 01F9 ;
STEP CALL STEPCO ;GET DIGIT FROM TABLE INTO W
MOVWF PORTB ;SWITCH DRIVE OUTPUTS
RETURN ;RETURN
STEPCO MOVF UPBYT, 0 ;LOAD UPPER BYTE ADDRESS
MOVWF PCLATH ;TO PC UPPER BYTE REGISTER
MOVF INDEX, 0 ;GET TABLE OFFSET INDEX
ADDWF PCL,1 ;AND ADD TO PC LOWER 8 BITS
; THE SUBROUTINE 'STEPCO' MUST BE LOCATED AS SHOWN
; IN ORDER TO ALLOW THE 'TABLE LOOK UP' FUNCTION TO TAKE PLACE
; THIS HAS BEEN ENSURED IN THIS EXAMPLE BY THE 'ORG' 01F6
; WHICH HAS FIXED THE 'MESGE' LINE AND ALL SUBSEQUENT CODE
; THIS IS ONE OF MANY POSSIBLE WAYS OF FIXING THE CODE.
; TAKE CARE NOT TO CROSS PAGE BOUNDARIES AS 'UPBYT' REFERS TO
; A SINGLE PAGE ONLY - 0200 TO 0300 IN THIS CASE.
;The PC (program counter) is loaded with the table address from UBBYT and
;INDEX and so jumps to that address, and returns with the data following
;the RETLW instruction.
; ;UPBYT 02, INDEX 00
RETLW B'00001010' ;STEP0 -'HOME' POSITION
RETLW B'00000010' ;STEP0.5
RETLW B'00000110' ;STEP1
RETLW B'00000100' ;STEP1.5
RETLW B'00000101' ;STEP2
RETLW B'00000001' ;STEP2.5
RETLW B'00001001' ;STEP3
RETLW B'00001000' ;STEP3.5
END
| | #9 |
I have posted the code as suggested but had no response, can anybody help me cut out what I don't need in it, I would like to make a simple file to run the motor back and forth and be able to set the speed/degrees of movement to atleast start to understand how to programme the PIC.
| | #10 | |
This is still ongoing, Eric Gibbs (a member) has been helping me with this project for a while now but has gone on holiday for a few months, heres my question Basically I have everything I need BUT at the slow speed the motor is resonating horribly, which I can understand as it echos the steps. The motor supplier has said the motor can run at 2000 rpm so I would just need to increase the speed and gear it back down at the output shaft, my code Quote:
What else is limiting the speed? | ||
| controller, motor |
