Hi Electro Tech, I need an optical sensor that can be "tripped" when a thin piece of paper moves past it. Can anyone suggest a type of small optical sensor to start looking into? My goal is to make a system where: When the optical sensor is "tripped" it tells, through use with an arduino board (arduino.cc), a fan to move. Any suggestions on where to start??? Thank you so much! -MBE | |
| | #2 | |
Do you need to be able to distinguish a thin piece of paper from thick piece of paper or a cat walking by or something? Torben | ||
Thanks Torben, I think if I have a phototransistor on one side and a photodiode on the other that might do it. BUT I have used Infared phototranisistors for a pulse detector. I think it is basically the same principal, right? The only thing about using an infared sensor is that it seems SO sensitive. It seems to be affected by ambient light more than (i think) a red laser light would be. Is that right? I think I would prefer if I could actually see the laser light and only if and when that very specific laser was interrupted my fan would turn on. I said a thin piece of paper, because I want it to be pretty sensitive, but not so sensitive that a cat would blow the paper as it walked by. I'm sure a thick piece of paper would be good enough for my needs, actually maybe even better. I will fill in my profile, I have just been so excited reading all the posts and asking questions that I havent gotten to that part. But, I am in Seattle Washington and have ordered plenty from Digikey and Mouser in a very short amount of time. I am VERY new to electronic work and dont really know anything... So thank you for anything and everything you all have to offer. -MBE | |
| | #4 | |||||
Hope this is at least giving you some ideas. I'm posting this now but I'll try to dig up some references on the modulation in case that's needed. (You might have guessed that I'm a hobbyist and not an EE or anything. I'm learning too but I have a few projects under my belt.) Torben | ||||||
Hey Torben, I guess I meant an LED and a phototransistor then. Sorry, the electronic terms are still not concrete in my mind. What I am trying to do is: A person will blow into a tube. They will blow on the piece of paper, which will trip the sensor. The sensor will then turn a heating element and some fans on. SO The tube that they blow into can be dark, so ambient light, I guess isnt the biggest problem...thankfully! So if I use the bic pen idea (thank you, sounds good) then the laser will be infared or not? I think I know what to buy if it is infared light we are talking about, but I dont really know what to buy if it is not infared. Do you have any suggestions? The pulse detector that I made is for detecting heart rate using an infared LED and a phototransistor. I just didnt really think that infared is necessary in this case. What do you think? Thanks for your time, Molly | |
| | #6 | ||||||
If you're underpowering the diode it may give off red light, but won't actually lase. To get it to lase, gently boost the voltage up to around 4.5V and suddenly the light will turn noticeably "speckly"--this is a result of the laser action. Quote:
Torben | |||||||
| | #7 |
OK!! I'm going to the dollar store! You're awesome! | |
| direction, idea, optical, sensor |
| COnnecting 2 telephone Sets via optical coupler | waqar | General Electronics Chat | 4 | 20th April 2008 04:07 AM |
| Sound quality from optical out and SPDIF???? | Electricman2K5 | General Electronics Chat | 8 | 1st June 2006 09:08 PM |
| Converting optical signal to a pulse | tkvenki | Electronic Projects Design/Ideas/Reviews | 2 | 31st January 2006 06:22 PM |
| some kind of optical sensor | ee838l | Electronic Projects Design/Ideas/Reviews | 4 | 26th February 2004 07:54 PM |
| Digital Optical output for MiniDisc Player | Peter | Electronic Projects Design/Ideas/Reviews | 1 | 20th January 2003 05:20 AM |
