I'm trying to build (in pspice first) a system to detect a modulated signal using an envelope detector. I'm first using the MULT part to act as the 'mixer' and then use a BJT amplifier to increase the signal voltage (I tried using a regular OPAMP but to no avail). I'm getting the amplifier signal fine, but when connecting the output to the envelope detector, the amplifier signal becomes very small. I tried putting a capacitor in series with the envelope detector which does return it to the original voltage level but then the peak-to-peak voltage is very small. Either way, the output at the envelope detector is useless. Is there something I'm missing here?
Thanks in advance. Edit: here's the circuit http://img69.imageshack.us/img69/1730/picture1nu0.png |
It's because you are using a mixer instead of an AM modulator. So instead of a modulated signal, you are just getting two CW signals of 780Khz and 760khz. There is nothing in the "envelopes" so to speak.
--- The days of the digital watch are numbered. --- Last edited by kchriste; 7th October 2007 at 11:50 PM. |
The base voltage of the transistor is too high, the collector resistor's value is much too high, the load resistor's value is much too low and the supply voltage is too low.
The transistor is severely saturated, overloaded and can't amplify. Using a 9V supply, bias the base at about 1.1V. Then the emitter voltage is 0.5V. With a 1k emitter resistor the emitter current is 0.5mA and a 7.5k collector resistor will set the collector voltage at 5.25V where it can swing up to 9V and down to 1.1V. Connect a capacitor across the emitter resistor for much more voltage gain. Increase the value of the load resistor to about 5 times the collector resistor's value.
Uncle $crooge |
(permalink) | ||
I figure i'd ask another quick question since this thread is still somewhat recent. I was unable to implement an AC amplifier using an op-amp. My attempt is below. What am I doing wrong?
http://img210.imageshack.us/img210/4206/picture1zf5.png |
--- The days of the digital watch are numbered. --- |
Simply google for "741 tutorial", there's LOT'S of infomation out there - opamps are probably the simplest components to use. |
Uncle $crooge |
can anyone point me to a website that has the circuit model for an OPAMP ac amplifier. I just tried implementing one I found online today but was not getting anything. my friend said i have to build a voltage divider at the input of the opamp but was not very specific.
thanks in advance. |
There are thousands of sites that explain how to bias the input of an opamp with 1 resistor and setup negative feedback using 2 resistors for it to have a high input impedance and any amount of gain that is needed at low frequencies.
In Google enter Opamp Tutorial or Opamp theory.
Uncle $crooge |
If you want to use a legacy OpAmp then the LM318 would be a better choice than the LM741 though you'll only have a gain of around 25db at 1Mhz with the LM318. For more performance, you could try an OpAmp like the OPA356 by TI. It's a simulation, so cost shouldn't be an issue.
Edit: I've modified your diagram so the OpAmp has a gain of 10 instead of infinity(well in theory):
--- The days of the digital watch are numbered. --- Last edited by kchriste; 11th October 2007 at 05:01 AM. |
Did you see in the datasheet for the LM318 that its output is fine up to 1MHz?
Uncle $crooge |
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 01:45 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 09:48 PM |
| Enquiry For some signal questions | shermaine | Electronic Theory | 6 | 5th December 2006 06:02 AM |
| Anybody got information on line driving a c-sync signal? | FusionITR | General Electronics Chat | 8 | 15th April 2006 04:16 PM |
| Yet another LED taillight controller...... | NickK | Electronic Projects Design/Ideas/Reviews | 1 | 31st March 2003 05:37 PM |
