Old 28th September 2007, 05:29 PM   #1
Default signal boost+treble boost circuit
Hi, I'm trying to design a circuit with two stages.
1) a boost stage which will take an input signal and boost it by 6-20 dB (2 - 10 V/V). I'm not sure whether a BJT or a MOSFET would be best.
My main problem is dc biasing. I'm not sure what region is best, and whether I can follow the Vcc/3 rule for biasing or not.
Also, I don't have any real experience designing around a potentiometer... what value would be the best? How do I incorporate it into the design process?
2) How can I boost the higher frequencies? Could I use a high pass filter with a stop band that is of higher gain than 0? I don't want to cut the lower frequencies, just boost the higher ones.
Also, is it better to adjust the gain of a set pass band, or to have a set gain, but an adjustable pass bandwidth?
Thanks,
Mark
mlugg is offline
Old 28th September 2007, 05:48 PM   #2
You need to tell us EXACTLY what you're wanting to do - at a guess I would say you need to lookup opamps!.
Old 29th September 2007, 01:39 AM   #3
If you like a lot of distortion then make an amplifier with a single transistor.
The treble boost will increase the distortion.
audioguru is offline
Old 30th September 2007, 06:17 AM   #4
is it applicable to electric guitars?
hardcore misery is offline
Old 30th September 2007, 07:02 AM   #5
40% distortion is nothing for electric guitars.
The Fuzz Face distortion making circuit makes much more distortion:
Old 30th September 2007, 10:05 AM   #6
what is the supply voltage for this FUZZ FACE circuit? can it be useful to the guitars cavity? or inside a guitar pedal?
Old 30th September 2007, 03:20 PM   #7
yeah, I'm trying to design a pedal
mlugg is offline
Old 30th September 2007, 03:56 PM   #8
ok i'll eye on this
Old 30th September 2007, 04:10 PM   #9
Look in Google at Fuzz Face Circuit.
There are links to the original one with old PNP germanium transistors and the circuit I simulated that has modern NPN silicon transistors.
It works from a 9V battery.
boost, circuit, signal, treble
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 13 19th February 2009 07:27 AM
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 02:45 PM
Yet another LED taillight controller...... NickK Electronic Projects Design/Ideas/Reviews 1 31st March 2003 06:38 PM
Mixed Signal Circuit Simulation Software Nonx General Electronics Chat 4 13th March 2003 02:05 AM
