HI, all i have to make an inverter of 1000 watts from 12dc to 220 ac 50hz inverter. i have 500 watts dc to ac same spec circuit diagrame,
the thing i need is to 1)1000 watts 2)Of which specification transformar i have to replace e.g how much kg, which wire, which core, or how much turns primary and secondary, final how much amperes it will bear? plzzzz do some help change schematic ------------------------------------------------- |
Experienced Member
First, figure out where you're going to find 12V at about 120 amperes for more than a few minutes at a time.
Then get back to us. |
thanks for reply.
here in my city one shop is making inverter of 1000 watts. for more than 2 hours continously. it is a good question wht source they use, they use tractor's battry which is off 102 ampers and 12 volts. when light came it started to charge by main ac supply when light off it started its work..... it is a nice source of power than off generator which uses fuel.... |
how can i change it from 500w to 2000w
Experienced Member
Best just to buy a 2000W inverter, cheaper than building one yourself.
Experienced Member
Your transistor will not be happy. (C10161,2N3055, 2x2N3055) You will be running 150 amps and the C-E voltage drop will be about 3 volts or 450 watts loss. The LM324 can not pull up to 12 volts. C1061 has some voltage loss. Every time you add a transistor you will loose 0.6 volts. That all adds up to 3 volts.
You need to find a different transistor circuit that has much less loss. Hint use NPN and PNP. Or use MOSFET. |
Experienced Member
That lousy old inverter was desisgned for 3rd world countries that have plenty of 2N3055 transistors but no power Mosfets.
The one in the attachment was recently modified by the moderator, MP. Its output transistors operate poorly with 10A but with a 500W load they each must conduct 25A. The resistor and capacitor values in its oscillator are very wrong. It doesn't have voltage spike protection diodes. It uses two quad opamps instead of a single dual opamp.
Uncle $crooge |
Experienced Member
Those opamps are pointless anyway. A better job would be done by a pair of small PNP transistors with 150 ohm collector resistors.
This design is bad in so many ways that it's hard to count them. |
why do power mosfets IRFZ44 keep burning up in my inverter?
Experienced Member
There can be many reasons, hard to say without seeing the schematics. For example shoot-through current. Exceeding maximum current or voltage. Overheating (MOSFET thermal runaway) .... you can use higher current, voltage , lower Rds-on MOSFET but first you need to identify the cause of the problem.
| 12Vdc -> +-12Vdc | bh00 | General Electronics Chat | 9 | 12th August 2007 09:33 PM |
| I need a 1000W 12VDC - 240VAC inverter | ebuka_2 | Electronic Projects Design/Ideas/Reviews | 5 | 2nd June 2007 06:55 AM |
| using a 320W flash with a 150W inverter | denoise | General Electronics Chat | 5 | 19th February 2006 03:44 PM |
| inverter or inverter? | glmclell | General Electronics Chat | 1 | 11th August 2004 12:16 AM |
| 12VDC battery to 12VAC inverter? | Troy Jollimore | Electronic Projects Design/Ideas/Reviews | 4 | 7th June 2004 12:23 AM |
