Old 30th October 2007, 12:48 AM   (permalink)
I have just realised what your problem must be.
Your drawing shows a connection between pins 1 & 12 of U1.
Is this connection really there? If it is, check if it is a good connection, ie. inspect it visually and, if it looks OK, measure the resistance between pins 1 & 12; it should be a low resistance, ie. < 1 Ohm.
If these pins are not connected then you will experience what you have described since the Modulo 5 counter won't be being driven by the Flip Flop, ie. only the flip flop will be changing.
In other words, Qa (pin 12) must be connected to input B (pin 1)
Len
ljcox is offline   Reply With Quote
Old 30th October 2007, 11:30 AM   (permalink)
WOW WOW WOW WOW WOW
finaly the counter is counting perfectly
0,1,2,3,4,5,6,7,8,9
the breadbord hole where wire of pin1 to pin12 was defected
I used another hole in the breadboard to connect pin1 to pin 12
and thats it
counting with no problems
thank you very much ljcox
also BIG thanks goes to audioguru and all other members who'ed helped me
all the best
cannibal is offline   Reply With Quote
Old 30th October 2007, 09:33 PM   (permalink)
Originally Posted by cannibal
WOW WOW WOW WOW WOW
0,1,2,3,4,5,6,7,8,9
and thats it
all the best
You're welcome. I'm glad that we were able to help.
It looks like you need more experience at fault finding.
The general principles are:-
Do a visual inspection and look for bad connections, short circuits, etc. and if any joints are soldered, check for dry joints.
If that does not resolve the problem, make voltage measurements. In your case, you would have measured a different voltage on pins 1 and 12.
If pin 12 was high, you would have seen a low on pin 1. So therefore there must not be a connection between them. Note that if pin 12 was low, pin 1 would also be low and therefore you would not know that the connection was faulty. So you need to change the state of the counter to check both cases.
If you have a multimeter with a continuity function, you can check for continuity between points that are purposed to be joined. So if you put one probe on pin 1 and the other on pin 12, there would have been no continuity.
Finally, when I am building something, I check the components before I insert them. New components are rarely faulty, but if one is and you don't check it, then having to fault find when the construction is finished can waste time.
Len
Old 31st October 2007, 11:59 AM   (permalink)
Thanks for the tips
Is it possible to make it count to 99?
and how the connections can be done?
by the way I decided to use power supply rather then 9V battery
Old 31st October 2007, 03:16 PM   (permalink)
Of course. But most modern circuits use a microcontroller or Cmos ICs.
I haven't used old TTL since about 1972 when I started using Cmos instead.
Look in Google for Two Digit Counter Circuit.
Old 31st October 2007, 04:22 PM   (permalink)
Done
pin14 of 74LS90 from circuit2 goes to pin 6 of 74LS47 from circuit1
power electronics circuit analysis ptewright Electronic Projects Design/Ideas/Reviews 2 25th November 2006 08:16 AM
Need help about a 7805 regulator circuit ! Zarkabul Electronic Projects Design/Ideas/Reviews 26 13th June 2005 06:07 PM
Circuit auto OFF feature after no events design Uman Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 05:34 AM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 10:45 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 12:30 AM
