Old 28th September 2007, 06:14 PM   (permalink)
Is this what you want?
Old 28th September 2007, 08:41 PM   (permalink)
hello
I tested the circuit you provided in breadboard
I faced these problems
1) the buzzer making sound when there is light and that should be revered
the buzzer should make sound if it's in dark
2) the buzzer not stoping making sound
3) the sound of the buzzer is too week
cannibal is offline   Reply With Quote
Old 28th September 2007, 10:30 PM   (permalink)
I don't see why you need Q3 and R8.
Connect the buzzer to the 555 pin 3.
Len
ljcox is offline   Reply With Quote
Old 29th September 2007, 05:37 AM   (permalink)
hello
with out Q3 and R8 it won't work
Mr audioguru
I tried to test again your circuit and it's working fine
but facing one simple problem
1) the buzzer won't stop when it get activated
I appricate your help
Old 29th September 2007, 01:01 PM   (permalink)
In my circuit the 555 is a monostable exactly like in its datasheet. The 10k resistor holds its pin 2 high so it can time out and stop the buzzer.
When it gets dark then Q1 turns off. Then R4 turns on Q2. The collector of Q2 then has a negative-going pulse through the 47nF capacitor that triggers pin 2 of the 555 so it makes a timed output for the buzzer. R4 and R9 are 10k ohms and R5 is 470 ohms.
Old 29th September 2007, 01:37 PM   (permalink)
I did everything that you said but still the buzzer wont stop
please see this
is this the capacitor that I have to use ? the one of 47nF
it's writting on it
473
Old 29th September 2007, 02:45 PM   (permalink)
A fuzzy photo without any light is useless.
A capacitor marked 473 is 47nF.
Disconnect everything from pin 2 of the 555 except the 10k resisitor to the positive supply, the 47nF capacitor and the other 10k resistor to the positive supply at the other end of the capacitor. Ground the input for a moment like this:
The 555 should get triggered, the buzzer should sound for the timing then stop when the 555 times out.
Please stay in only one website's forum.
Old 29th September 2007, 03:35 PM   (permalink)
I done the circuit
and I touched the * to the ground then the buzzer made sound
but didn't stop
there was no timeout for 555
Old 29th September 2007, 03:45 PM   (permalink)
Originally Posted by cannibal
I done the circuit
Then either the 555 is defective, or the leakage current of C2 is too high or the value of R7 is too high.
If all your questions were on a single website then i could see the values of C2 and R7.
What is the voltage of the battery? Maybe its voltage drops too low when the buzzer is activated.
Old 29th September 2007, 03:49 PM   (permalink)
C2 is 10uF
R7 is 1M (brown black green)
battery is 4.5V
Old 29th September 2007, 05:00 PM   (permalink)
Replace C2 because it might have too much leakage current then it will never fully charge. Make certain it isn't connected with backwards polarity.
The minimum operating voltage for a 555 is 4.5v and yours might drop lower when the buzzer is activated. So try a 6V or 9V battery.
Old 29th September 2007, 05:55 PM   (permalink)
I replaced the C2 with new one (10uF)
the polarity connection checked correct
battrey changed to 9V
the problem still
Old 29th September 2007, 08:59 PM   (permalink)
the problem still
Maybe the 1M pot doesn't conduct.
Replace the defective 555 IC.
Old 30th September 2007, 03:46 AM   (permalink)
Hello
Just want to make sure before buying new 555 IC
after how many seconds the 555IC should time out ??
because I waited for 2 minutes and no time out
Old 30th September 2007, 04:04 AM   (permalink)
after how many seconds the 555 IC should time out ??
Why ask? Simply look on the datasheet.
1.1 x 10uF x 1M= 11 seconds with the pot at max resistance. They show a graph that looks like 8 seconds.
The 10uF capacitor could be actually only 8uF or 12uF and the 1M pot could be only 800k or 1.2M so the time will be somewhere from 7 seconds max to 16 seconds max.
Since you replaced the capacitor and made certain its polarity is correct then either the 555 is bad or the pot doesn't conduct.
Before buying another 555 try a 1M resistor to replace the pot.
power electronics circuit analysis ptewright Electronic Projects Design/Ideas/Reviews 2 25th November 2006 08:16 AM
Need help about a 7805 regulator circuit ! Zarkabul Electronic Projects Design/Ideas/Reviews 26 13th June 2005 06:07 PM
Circuit auto OFF feature after no events design Uman Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 05:34 AM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 10:45 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 12:30 AM
